Old 09-13-2012, 06:09 PM   #1
Ironhorse
Ironhorse's Avatar
NP205 Transfer Case Brkt. ?
Hopefully will be able to remove the transfer and trans (sm465) tomorrow from my '71 4x4. Removing the sm465/np205 and swaping to TH350/np205 auto setup. After removing the transfer case to frame bracket on the RH side I noticed it has a crack thru both bolt holes. Apparently cracked years ago , and it was welded on top of the bracket so the bracket to frame mating area is smooth. After doing a search I read that the General quit using the frame bracket in '72? I don't do a lot of off-road driving but usually keep any thing I remove in place when I go back together. Been thinking perhaps cut and weld a doubler plate to help strengthen the bracket. Is this an issue or can I leave it off?
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 09-13-2012, 07:58 PM   #2
whiskeydented
whiskeydented's Avatar
Re: NP205 Transfer Case Brkt. ?
I don't think they quit using that bracket in 72 because I know I've removed one of those from a 73.
If I'm not mistaken that bracket was only used on the 4 spds. The autos had a rod that went from the t-case to I believe the bell housing. But I'm really not familiar with the earlier trucks. Fwiw my 78 does not have that bracket on the t-case.
whiskeydented is offline   Reply With Quote
Old 09-13-2012, 08:15 PM   #3
Ironhorse
Ironhorse's Avatar
Don't have any knowledge at all on the auto 4x4's as I am doing this swap from a standard to auto. Any idea of what the rod looks like and just how it attaches or how I can search for a picture to look at? Maybe I could fab something if I had an idea of where to start.
Wellington, Ks
Old 09-13-2012, 08:27 PM   #4
Billhilly
Billhilly's Avatar
Hey Ironhorse,
Have a read of what Larry is saying here http://67-72chevytrucks.com/vboard/s...d.php?t=491001
From memory the consensus was leave it off. Hope this helps.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 09-13-2012, 09:36 PM   #5
Ironhorse
Ironhorse's Avatar
Thanks Billhilly, there was some good reading there. Seems as if the concenus is NO bracket and NO rod for either 4x4 set-up std. or auto.
Wellington, Ks
Old 09-18-2012, 10:27 PM   #6
jaros44sr
jaros44sr's Avatar
I could give you those brackets, sandblasted primed and painted, with poly mounts....but i wouldnt be doing you a favor
Youd be cursing my name when something broke
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
