Separating the steering column shaft from a manual steering box
After searching the forum for a solution to this problem, I have mostly figured this out. However, the one piece I cannot figure out is how to separate the "wavy" end of the shaft from the actual steering box itself. It seems to be connect with giant rivets, but it must disconnect somehow. Any help is appreciated.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Separating the steering column shaft from a manual steering box
You will need to grind the heads off of the rivets that attach the flange on the end of the steering column shaft to the rag joint, to separate the two. Then when you re-assemble, just use the appropriate size bolts with lock nuts.
#3 | |
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
That makes perfect sense! Thank you so much for the answer. I guess it wouldn't be a bad idea to replace the rag joint while I'm at it.
