09-13-2012, 06:46 PM | #1 |
GM Tilt column Questions
I found a GM Truck tilt but the tilt joint has some slop is that a bad bearing or is it possible the bearing collar is just loose? The guy is asking $300 for it even with the slop. If the column needs to be rebuilt how much is it worth as a core I need to know how much to offer. Thanks in advance. |
09-13-2012, 07:15 PM | #2 |
Re: GM Tilt column Questions
What's a rebuild kit worth? I'm going to rebuild my non-tilt one (after 100,000 miles and 40 years I think any of them should be checked), and I imagine its no difference in price for the rebuild.
I don't think "new" ones are available, unless you want an aftermarket one. But if your cost for the core plus the rebuild comes to the same or less than an Ididit, you're probably at a fair price.
09-13-2012, 07:39 PM | #3 |
Sometimes the 4 bolts holding the upper part of the column become loose, easy fix after you remove the pivot pins.
Wade , JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!! , Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570 Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro |
09-13-2012, 08:53 PM | #4 |
There is a bearing retainer and nut that could of come loose on the upper most bearing, although it would be hard to tell if this is the case, unless you would be disassembling it
Would be nice to know if the tilt knuckle was reprod...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
