water in cylinder, now wheres the leak?
hey guys i finished pulling the heads today. okay, cylinders 2,4,6,8 did not have water sitting in there. just pulled off the other head and cylinder 5 and 7 have water sitting on the piston. the gasket is still in place, but where would it be leaking by looking at the gasket?
Re: water in cylinder, now wheres the leak?
another
![]() Join Date: Mar 2012
Hopefully just the head gasket... maybe cracked block...
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
Active Member
![]() Join Date: Jul 2007
Looks like by the front edge from the pic, but it really doesn't matter. A new gasket will take care of it if the heads check out okay and aren't cracked.
Did you pull the heads because it was smoking coolant out the exhaust or running hot? If so, I would have them completely checked while you have them out. Now if you pulled the heads just cause you wanted to see the inside of the engine, it may just be coolant that was still in the passages when you loosened them.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
if a cracked block, where could it be cracked? heads were pulled because of milky oil
Sorry I ment cracked heads, but a small crack anywhere where water and oil are circulating can lead to this problem. Hopefully its just the head gaskets. Inspect the heads, clean the surfaces, install new gaskets and hope for the best. Head gaskets fail all the time. Its not uncommon.
Also, make sure to seal the head bolts. Use Permatex white, it comes in a tube with a flat nozzle and torque to 65 ft. lbs in the roper sequence. Its possible the coolant is wicking up the threads.
