what headers are you runnin
I got a 66 with a 327 sitten in it. Its just the frame and motor. My next purchase is headers and i want to go with the type that are silver not sure what there called and i want a pair that are 2 7/8 i believe. So lets see some pics of what yall got out there and some info on them. Thanks
Posted via Mobile Device |
Re: what headers are you runnin
You want ones that are ceramic coated! And 1 5/8 inch header tubes.
60-66 Nut
![]() ![]() Join Date: Mar 2007
re you running a manual trans or an auto trans? Is this truck going to be lowered much?
The Hedman #69260's are the ones designed to be used in these trucks with either trans, but they have 1-1/2" primaries. The Hedman #69090's will work on these trucks with either trans, and are 1-5/8" primaries. Hooker #2452's will also work. However these are all long tube headers, and may hang down too low if you are going to lower your truck much. Those part numbers are for plain painted headers. Those are all available in ceramic coated under a different part number
Awesome thanks. Auto trans and not lowered.
Anybody got pics of the ceramic coated hooker headers installed?
Don't post on here much, but I do poke around a bit. I have a 65 with a 350 and borg and Warner t18. Looking for a set of headers that WILL NOT hang below the frame, because I plan on bagging it. Any advice?
Anybody no if headers for 67-82 camero would fit our trucks with out any mods? I only ask cuase i can get a brand new pair that are stainless steel for 175 from a guy that spent 300 for them but wont fit his project.
My chevy 350 is ruinnin Eagle headers.
1966 Chevy C 20 Lwb (Now a project)5.7 400hp 1996 Chevy Silverado Reg Cab Lwb (Daily Driver) 5.7 2000 Chevy S-10 Ex Cab Lowered 4/4 4.3 (For Fun) 2008 GMC Sierra Ex Cab 5.3 (once a month driver) Wife's 74 Ranchero 500 351 Cleveland (One Owner) My name is Mike and im in So. Cal (Hi Desert) |
60-66 Nut
If you are running a manual trans with the original bellhousing crossmember, those will not work. If you have converted to an auto trans, they should work, but I can't say there won't be any mods necessary. They will likely hit the motor mount brackets.
What about, if you have a 350eng.ounted in the forward mounting holes? Them what headers (ceramic) will clear the 1976 front end crossmember, and allow good access to the oil filter and the drain plug, the first set I tried did not allow either, (she is a 1965,fleet, c10)
I went with a set of flowtech's a few years ago, if memory serves me they were for a full size car and fit like a glove. I think they offer them in ceramic coated also.
