09-15-2012, 06:44 PM | #1 |
Differential/Gearing identification
I have an 83 c10 which was a 250/auto truck, now a 350/th350. Id really like to put an auburn/eaton diff in it to get rid of the "limited slip". My question is what gearing would I MOST LIKELY have, and would my current ring and pinion assembly bolt up to a auburn/eaton diff?
The truck turns very low rpm in the 40-50 mph range... |
09-15-2012, 08:45 PM | #2 |
Moderator
Re: Differential/Gearing identification
Do you have the SPID sticker in the glovebox?
You'll find the original factory gearing and presence of limited slip diff on the SPID stcker.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
09-16-2012, 06:15 AM | #3 |
MOST likely is 3.08. But it could be a wide range depending on what the truck originally was. I've had 4.11 to 2.37's in my half tons, from the factory.
If the carrier is the same series, yes your gears will swap. But unless they are relatively new, and you know exactly what you're doing, it's better to just put in new gears. But you need to know the ratio. Why do you want to get rid of the limited slip? That is a 'posi'. The two you mentioned are usually posi's. Do you actually have an 'open' diff and want a posi?
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
09-16-2012, 01:31 PM | #4 |
The ten bolt has auburn or eaton units available but I would suggest the eaton since they can be rubuilt.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
