69 c10 Bleeding brakes question
I just installed new cylinders on the front of my truck and was getting ready to bleed them when I noticed that I could not get a open end wrench on them to bleed them like I could the rear when I changed them. Anyone know the appropriate tool to use to be able to get onto the bleed valve in the front??
Re: 69 c10 Bleeding brakes question
can you post pictures? curious cause i've never run into this problem
The Older Generation
I have the same problem on my '69 Suburban. The bleeder screw is too close to the spindle. It has the long bleeder screws and I'm wondering if the short ones would be better. I think I am going to remove the bleeder screws, plug the holes, and clearance the spindles with a die grinder... I can't even get a 1/4" drive socket on mine. LockDoc
My 70 a socket will fit but its tight, going to take 2 people for sure I won't be able to do the fronts by myself..
Posted via Mobile Device |
I will post pics today and yeah it is definatly going to take 2 people cause its a pain to get on it. I might try and put a shorter bleeder on it thats a good idea!
Let us know if that helps...
LockDoc
Pics here!
![]() ![]() Posted via Mobile Device |
A socket works on mine.
67 C10 swb bored out 350 granny 4 speed I come from a long line of moonshiners |
I had this problem too on the kids 67 before we did the disc swap even this wrench wouldnt fit.
I think loc doc has the best solution it would'nt take much
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#11 | |
