Old 09-16-2012, 09:29 AM   #1
66gmc250
help lowerin a 66 gmc lwb on a budget
i have been wanting to lower my gmc a good bit want to know how low i can go without changing the factory drum brakes. i cant seem to find any kits for my truck every where i look its 4 coil kits where i have coils in the front and 2.25" leafs in the back. saw a axle flip kit for the back to lower it but dont know how much that lowers it and what would i have to do to match the front
66gmc250 is offline   Reply With Quote
Old 09-16-2012, 09:58 AM   #2
tincan1966
tincan1966's Avatar
Re: help lowerin a 66 gmc lwb on a budget
An extreme budget drop(we did this on our shop truck a couple years ago-also a GMC)
Cut one full coil off the front springs and cut bump stop rubbers in half on front
Removed leaf springs in rear, leaving only the top 4 leaves. The load capacity is a little lower but the ride is good.
tincan1966 is offline   Reply With Quote
Old 09-16-2012, 10:00 AM   #3
tincan1966
tincan1966's Avatar
Not a great pick, but I am 6'1" so you get an idea of the truck height.
Same '66 GMC from above pic.
Old 09-16-2012, 11:17 AM   #4
Narxoleptic Customs
I'm riding in the rear like tincan. Up front I did s10 4 cyl springs and had my factory control arms stepped. CArms cost me $125...
That's on a 17" rim w a 27.5" tall tire.
Narxoleptic Customs is offline   Reply With Quote
Old 09-16-2012, 11:51 AM   #5
66gmc250
what if i cut the coils and stops like u mentioned and then flipped the rear axle would i saw a kit to flip it but i read somewhere that u would have to modify the drive shaft?
Old 09-16-2012, 01:11 PM   #6
Narxoleptic Customs
A flip shd drop it like 5-6"... U may have to have the driveshaft shortened but idk...
Old 09-16-2012, 09:40 PM   #7
66gmc250
Cool Re: help lowerin a 66 gmc lwb on a budget
i think i will stay away from the flipping of the rear till i get more info i figure if i did that it would be to low in the back because i can only go so low on the front with just cutting the springs me and my buddy might tackle it one weekend
Old 09-16-2012, 10:06 PM   #8
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
You can pick up some axle pads for cheap, and flip it.
Extend shackles....relocate hangers.
Cut springs.....I would remove bumpstop mounts all together.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-16-2012, 10:47 PM   #9
66gmc250
Will removing the stops affect the ride quality
Old 09-20-2012, 09:13 PM   #10
66gmc250
Can u cut more than one coil ?? Or is that not recommended
Old 09-20-2012, 10:24 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Only if you bottom out.. I like having a little rubber there for those hard bumps you might hit. My bump stops are kinda thin but there is something there.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
