Never seize on spark plugs
Anyone else do this. I am really not an advocate of it, seams it would restrict the grounding properties of the spark plug.
This 87 was not running as smooth as I would prefer so I checked the plugs. Has AUTOLITE PLATINUMS in it, not real trusting of those eather, however, seams there was only one that did not have the never sieze on it and it was golden brown. The others, all of the others only had a small brown spot and the rest of the electrode was white. I cleaned the never sieze off of the plugs but didn't have any cleaner to clean the plug holes. I will when I replace the plugs but FOOTBALL is on today so it will have to wait. Does anyone else use never sieze on the spark plugs ? Posted via Mobile Device
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
Re: Never seize on spark plugs
I do, just a little dab on the threads is all you need though.
Only use anti-seize for plugs in aluminum heads. All others a drop of oil on the threads helps them screw on.
There was ALOT on there, I mean it was hooped up on the seating shoulder on the plug
I use it on every plug i put in and never had any problem.
Platinum plugs are a real bitc* to lite with our ignitions. They are best For people who don't change their plugs ever since they last a long Time. Just get some copper core plugs and be happy all your voltage is being used
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I always use a bit of antisieze on the threads of plugs. Thats the key, a bit, and only on the threads.
Alex. |
x2
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
I use copper anti-seize on the threads.
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
I use it on all spark plugs, especially aluminum heads.
Its completely not neccessary to use anti sieze on spark plugs. The factory doesnt on any spark plug regardless of the material of the cylinder head. The antisieze will foul a spark plug. Its way more important to use the proper spark plug for the application.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Moderator
![]() Join Date: Oct 2008
Permatex Neverseeze is electrically conductive like Noalox. I use it on lightly used gasoline engine spark plugs like my weed trimmer, mower, and tiller engines... Becoming a bigger fan of compact low HP Yanmar 1 & 2 cylinder diesels for the mower and tiller because of the recent increases of ethanol in gasoline.
I also use it on my glow plug and injector threads. The key is moderation. Getting it on the insulator internally or externally will raise hell with the spark.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#13 | |
![]() If it's been years since they've been removed,,,,,good luck. Using them on a steel head also isn't a bad idea. If you are fouling plugs,,,you're putting too much on. Anti seeze is only meant for the threads, not the electrode. |
#14 |
I use it on the threads only. NOT on the Tapered Seat. It will get all the ground it needs thru the tapered seat.
#15 |
yes use it, you only need a little, and no matter how much you used it wouldnt keep it from grounding.
