09-16-2012, 12:21 PM | #1 |
Starter Prob...I know..again
New to the forum. I have acquired a 1972 Chevy BB 402 long bed truck. The problem I have is it starts right up everyday right off the bat. But, after I have driven it for whatever amount of time and I kill it it won't start again. It barely turns over. I wait 10 minutes and it starts again. It acts like it will barely turn over but then it kicks off. Any ideas from you experienced truck guys. I am not new to cars and motors, but this one is getting me.
Thanks. |
09-16-2012, 12:34 PM | #2 |
Re: Starter Prob...I know..again
you need to install a heat sheld on your starter or route the exuast away from it. the heat from the exuast is causing the starter to overheat.
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff |
09-16-2012, 12:55 PM | #3 |
Thanks. I had not thought of that, but it makes sense. I did have an old Vette that I had to do that with. This truck has headers so I will look at it. Keep you posted.
Thanks again. |
09-16-2012, 04:01 PM | #4 |
This was my first thought, and I have no doubt that it will help. I had this same issue with my '72 SWB C-10, but I never got around to doing it. What I did do was rebuild my carb. Solving the starter issue never entered my mind as a reason for rebuilding the carb, or as a possible fix, but I have not had that problem since the rebuild. My carb was in dire need of one. Strange, I know, but that's what happened. All I can think is that the rebuild improved airflow or something?? BTW, stock ramhorns/exhausts.
09-16-2012, 05:41 PM | #5 |
Old Skool Club
I had the same problem, after I changed carbs from an Edelbrock AFB-type to an Edelbrock Q-Jet. As soon as I did it, the newer carburetor ran much better and much leaner. So, more heat was generated. A heat shield did the trick and never had it to happen again.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-16-2012, 06:43 PM | #6 |
Here's the ultimate cure for your heatsoak. You can change the cables, charge your battery, adjust your timing, add a heat shield, replace the starter and solenoid and even wrap your headers but this will cure it forever.
http://www.northernautoparts.com/Pro...tModelId=29888 |
09-21-2012, 10:21 AM | #7 |
Thanks everyone. Got the heat shield today and will install later today. I am thinking this will help. Keep you posted.
Truck has 402 BB, Edelbrock Performer, Holley 650 (don't quote me on that one), dual exhaust and headers, auto on the column. This three speed auto tranny drives me crazy not shifting after third into what I expect to be fourth gear. I will get used to it. Thanks again. Last edited by marman101; 09-21-2012 at 10:23 AM. Reason: Spelling |
09-22-2012, 09:26 PM | #8 |
Got the heat shield wrapped around my starter yesterday and took it downtown this afternoon. Parked it...tried to start it and the same thing. Barely wanting to turn over. We went and ate lunch...had me an Old Tom's gin and tonic and went back to try it again and of course it started. We were there about 45 minutes eating lunch.
So...back to square one. |
09-22-2012, 09:36 PM | #9 |
Grandpa in the rustmobile...
whats the timing..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-22-2012, 09:37 PM | #10 |
try retarding it a hair next time (turn dizzy clockwise if your lookin' in the hood)
09-22-2012, 09:47 PM | #11 |
I haven't gotten that far yet. I just got the truck a couple of weeks ago. I am just getting acquainted with it. Here are a couple of pics of the truck for those interested,
09-22-2012, 09:59 PM | #12 |
09-23-2012, 01:10 PM | #13 | |
Adjusted it back a degree then two. Then back to one. Was at 36 now shy of it. Idling better and performing a little better, but still won't start when you drive it and then shut it off. Also starting to knock a little like it has cheap gas in it. I put some 108 race fuel in it to see if it quiets down, but it isn't. Probably needs the carb rebuilt. |
09-23-2012, 03:38 PM | #14 |
Is it a high CR engine? Maybe back it off a little more still lol
09-23-2012, 05:56 PM | #15 |
you said you're running headers, how close does the fuel line get to the exuast? the heat could be evaporating the fuel? it would explain the fact that it is hard to start after running. also if the starter has been heatsoaked enough times it will be weak, witch could also be part of the problem if the motor has a high compression ratio
09-23-2012, 06:05 PM | #16 |
The remote solenoid will solve your problem BTDT.
Posted via Mobile Device |
09-23-2012, 07:35 PM | #17 | |
An old landlord of mine had a Reliant that was doing the same thing. He had taken it to a shop to have the starter replaced. while the tech was doing the repair he either lost the clip that held the heat shield off of the starter or just didn't feel like putting it on (it was a real PITA). He ziptied it to the starter. It only lasted about 6mths and it killed the brand new starter. My landlord brought the car to me. I found the problem and replaced the clip and starter. never had a problem again. BTW car (1984) only had about 42000 miles at the time 1999
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff Last edited by 71gmcburb; 09-23-2012 at 07:40 PM. Reason: spelling |
09-23-2012, 07:47 PM | #18 | |
Thanks. |
09-23-2012, 07:48 PM | #19 |
09-23-2012, 08:37 PM | #20 |
I had a 69 C10 with a 454 with headers that ate a starter about every 2 months and would start part of the time when hot ,, part of the time not,,,, very inconveniant when you stopped for a pop and ended up sitting there for a half hour til the truck would start again.
I changed over to the remote solenoid and eliminated both problems. I change all of my trucks to the remote solenoid. It also makes the starter a lot easier to change if you ever do have to change it. |
09-23-2012, 09:21 PM | #21 |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Change the starter drive end bushing.
09-23-2012, 09:50 PM | #22 |
09-23-2012, 09:57 PM | #23 |
Like the others mentioned it sounds like heat soak or timing too far advanced. I have never had a car with the heat soak issue but twice I have had the timing issue. Both times I backed the timing off several degrees and my problem went away.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-23-2012, 10:05 PM | #24 |
Had the same problem, put in a good gear reduction mini starter and that solved the problem...
09-23-2012, 10:08 PM | #25 |
Hey marman101 ...
to the site and from Ohio. I'm signed on to see what you find out
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
