09-16-2012, 06:05 PM | #1 |
Some more help on my truck.
We just replaced the under the dash wiring harness and we have everything hooked up and we don't have headlights, everything else works but those (brake lights, instrument cluster lights, etc.). We are not electricians by any means and we have no idea why they aren't working. If someone can help us out and possibly post some pictures with the process of it, I'd appreciate the help.
09-16-2012, 06:30 PM | #2 |
Rusty Nuts
Re: Some more help on my truck.
Check your dimmer switch. That will not let your head lights work
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
09-16-2012, 07:06 PM | #3 |
Well, we figured out that the high beams work and we're gonna replace the headlights now.
09-16-2012, 10:52 PM | #4 | |
I have brights but no dim unless I wiggle the plug around. Last edited by airdale94; 09-16-2012 at 10:53 PM. Reason: add |
09-18-2012, 07:17 AM | #5 |
Yeah, we don't have any lights but the high beams currently. That and my right back taillight doesn't work when I pull the switch out to turn on the lights, but it works fine when the lights are off.
09-18-2012, 07:26 AM | #6 |
Can someone help me out with why my back right brake light won't work when I turn my lights on?
09-18-2012, 07:32 AM | #7 |
Double check all your grounds. You can never have enough grounding on these trucks. I have two of these trucks and when I have a problem (like switches) I just go over and take the one off the working truck and then I have found the problem.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-18-2012, 07:34 AM | #8 |
I'll have to do that sometime this week or this weekend, when I check it I'll be sure to post back here and let you guys know.
