Old 09-16-2012, 10:40 PM   #1
gjones138
To cut or not to cut ....
I will be starting a frame-off restoration next week on a 69 lwb. I got an awesome deal on the rig, so I could not pass it up. This is my first truck project (have done dozens of cars), so I will just be doing a 4/6 static drop and replacing almost everything I touch. I love the look of a SWB, but do not mind the LWB look either. My question is, should I shorten the frame or leave it as is? Has anyone done this and regreted the decision or wish they did something else? I have looked for a Swb frame in the Dallas area, but can only find frames with rusted out cabs, frames that are not straight or just plain junk.
Any advice and insight is appreciated.
gjones138 is offline   Reply With Quote
Old 09-16-2012, 10:55 PM   #2
Del72Chevy
Del72Chevy's Avatar
Re: To cut or not to cut ....
Sell the lwb and use to money to find a short. I almost settled for a long but finally found a short it was well worth the wait in my opinion
My Build Thread
http://www.67-72chevytrucks.com/vboa...d.php?t=531309
Del72Chevy is offline   Reply With Quote
Old 09-16-2012, 11:52 PM   #3
gjones138
Thanks Del ... I have considered that route as well, but my current cab is too good to let go. I may part out out portions of mine and keep looking for a good SWB.
Old 09-17-2012, 12:08 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
I suggest you broaden your search a bit. I'll bet you can locate a decent frame not too far out. If not, dont be shy about cutting it. There is a really great article in our FAQ about the proper way to cut one.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-17-2012, 03:32 AM   #5
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Great FAQ write up on frame cutting.
Id find someone good with a welder to weld it though.
John
1999 Toyota Tacoma 4x4
Old 09-17-2012, 07:42 AM   #6
big_al_71
big_al_71's Avatar
If you have the skill then go for it, cut it the only thing that you are going to get is a huge $$$$ in value for it...
good luck!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-17-2012, 08:13 AM   #7
gringoloco
A guy with a truck
gringoloco's Avatar
Cut if you have the skills. Though, I have the skills and would rather do a frame swap, to save on time/work...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-17-2012, 08:53 AM   #8
CC69Rat
CC69Rat's Avatar
The advantage to cutting it is you keep the VIN numbers on the frame, BUT I think if I ever did it I would just swap the frame out. The only problem is the DMV in certain states, and the VIN on the cab / frame not matching up. In some states it's not a big deal ..
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-17-2012, 10:01 AM   #9
dougf
dougf's Avatar
Had a frame on a 78 cut to a shortbed and welded by a shop. It was easy and cheap. Needed a new driveshaft and brake lines, that's it. If your cab is good, I would definitely do it. Good luck finding a shortbed in good shape!
dougf is offline   Reply With Quote
Old 09-17-2012, 06:04 PM   #10
gjones138
This is all great advice! I have a place to do the welding for me with a frame table to ensure it's straight when it goes back together. If I'm cutting it, might as well C-notch it too ... This board has been awesome with the FAQ's and the great advice from all the members - best forum on any car/truck I have seen.
