09-17-2012, 09:23 AM | #1 |
Strange Noise
Hopefully one of you may have come across this and could give me some advice. I've got a loud clicking noise that sounds like it's coming from the center or right of center of my dashboard. It doesn't have a pattern and the best description I have is a toggle switch being flipped. Only starts above 20 MPH and gets louder and more consistent as I speed up but goes away if I slide the truck into neutral so it's only there under load.
This is my DD so I'd really like to figure out what this is before it breaks but I'm stumped! Jeremy |
09-17-2012, 09:50 AM | #2 |
Re: Strange Noise
i know you said its coming from under the dash,but are you sure its not a exshaust manifold leak sure sounds like it the way you descibe it.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
09-17-2012, 10:38 AM | #3 |
20' Daredevil (Ret)
Re: Strange Noise
Another possibility is a failed u-joint. Sound can travel and make it hard to tell just where it's coming from.
09-17-2012, 11:04 AM | #4 |
Newbee
Re: Strange Noise
Speedometer cable?
09-17-2012, 11:05 AM | #5 |
Member
Re: Strange Noise
1970 CST LB Fleetside, 402 BB, PS, PB,AC 1968 Firebird 400 conv. 1965 Chris Craft 17' wood ski boat (SN #0001) |
09-17-2012, 12:05 PM | #6 |
20' Daredevil (Ret)
Re: Strange Noise
Anything's possible, but I wonder if a bad speedo cable would go quiet when coasting... ?
09-17-2012, 12:26 PM | #7 |
Old Skool Club
Re: Strange Noise
Easy way to eliminate it is to take it loose from the back of the speedometer and shoot some WD-40 down the inside of the housing.
Mine used to make noise when it was cold, and the needle would jump. However, since I tore mine down...no more noises.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
09-17-2012, 01:31 PM | #8 |
Re: Strange Noise
Thanks for the tips guys. I'll try shooting the cable down. I've had one of those go bad before and this doesn't sound the same but it's a possibility.
09-17-2012, 02:30 PM | #9 |
Re: Strange Noise
Cracked flex plate ? Sure hope it's just the speedo cable!
09-17-2012, 02:38 PM | #10 |
Re: Strange Noise
is there a consistent pattern to the clicking? Maybe faster when you step on the accelerator or slower when you let off? OR is it completely random?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
09-17-2012, 08:16 PM | #11 |
Re: Strange Noise
It's not the speedo. Still there even with it disconnected. No pattern that I can discern. It always sounds like it's coming from the right side of the dash but can't pinpoint a location. It's not very loud but obvious and enough to be annoying. Where is the flex plate? I should give that a check.
09-17-2012, 08:23 PM | #12 |
Re: Strange Noise
I have the same noise sounds like paper is flapping on something (air coming in the cab) is what it sounds like to me. I'll take a look tomorrow and report back.... cheers, Pat
09-17-2012, 10:51 PM | #13 |
Old Skool Club
Re: Strange Noise
The flex plate is the flywheel, when you have an automatic. The torque convertor bolts to the flex plate.
I had a '56 Mercury, back in '65. It had a clanking sound at an idle that was quite noticeable. Those flex plates were different compared to the one these vehicles use. But, I'm still gonna guess that if your has any cracks, it's gonna be louder than a clicking sound, and it won't be on one side. Make sure your transmission dipstick tube is secure. It's on the right side.
09-17-2012, 11:29 PM | #14 |
20' Daredevil (Ret)
Re: Strange Noise
When my flex plate cracked, it was loud and deep -- it sounded almost like a rod knocking. That's the only one I have heard though, and I suppose they could make different sounds depending on where & how they crack.
09-17-2012, 11:42 PM | #15 |
Re: Strange Noise
That can't be it. This thing is really more annoying than loud. It sounds like an electrical circuit popping but I can't find anything on that side that could be doing it. The fact that it seems to move is all the more confusing.
09-18-2012, 12:41 PM | #16 |
Re: Strange Noise
So at the risk of sounding like an idiot, I figured out what the noise was. Turns out the screw was loose on my antenna and it shifted just enough that I couldn't see it but it was tapping on the rain gutter and transmitting the noise back down through the antenna into the dash.
09-18-2012, 01:15 PM | #17 |
Member
Re: Strange Noise
Don't feel bad, if it had been obvious you wouldn't have had to ask everyone-- and i don't think anyone guessed that as the possible problem...
Glad you found out what it was!!
