Old 09-17-2012, 08:30 PM   #1
rickrod3
Power steering Cooler
Got a leaking power steering cooler
Can it be by passed?
rickrod3 is offline   Reply With Quote
Old 09-17-2012, 09:39 PM   #2
clinebarger
Re: Power steering Cooler
If you have hydro-boost....You need a cooler.
If you have vacuum assist...Bypass it.
clinebarger is offline   Reply With Quote
Old 09-17-2012, 09:47 PM   #3
rickrod3
Thanks for the reply.
How do I tell which one I have?
I have a 98 C3500 with the 5.7 engine.
Rick
05 Silverado 2500HD. 6.0 engine
Old 09-17-2012, 11:55 PM   #4
benoit454
Chris
benoit454's Avatar
look behind your master cylinder on the firwall, does it have a big round thing behind it? If so it's vac. if not it's small and has hoses going from it to the power steering pump, that's hydroboost.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 09-18-2012, 07:43 AM   #5
rickrod3
Thanks for the info.
I have googled Hydra boost on the site and on google but could not find and overview of how it works or how it connects to the power steering system.
would appreciate if someone could give me a brief explaination.
Rick
Old 09-18-2012, 07:17 PM   #6
clinebarger
Rick
Hydro-boost Brake Booster
Uses power steering fluid pressure to decrease effort required by driver when applying brake system input force.When brake system input force is applied, pressurized power steering fluid is admitted to the rear of an apply piston, providing a decrease in brake pedal effort required. When input force is removed, pressurized power steering fluid is blocked off from the piston.
Pics....1st = Hydro boost....2nd = Vacuum booster.
Old 09-18-2012, 08:35 PM   #7
rickrod3
Thank you much
Rick
