Old 09-17-2012, 10:53 PM   #1
sickred72
What length of column do i need to buy?
Going to buy a flaming river tilt column with an auto shift but need the length? anyone have a clue? 1948 chevy truck...
sickred72 is offline   Reply With Quote
Old 09-17-2012, 11:14 PM   #2
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: What length of column do i need to buy?
hey buddy.i went with a 32" ididit and wish i would of got a 30" or maybe a 28".it all depends on header clearance on the joints and where you want the wheel.you might want to mock up the motor and tranny with headers on then get the column.i used s-10 conversion headers and they worked great.good luck.are you going to run a small block?
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 09-17-2012, 11:34 PM   #3
sickred72
crate zzz ( triple threat ) sbc with aftermarket edelbrock fuel injection
Old 09-17-2012, 11:38 PM   #4
sickred72
i should have just about everything i need for this project except rear end. I need to pull out the old one fit the wheels under the rear fenders and lower the body over them then measure. what should i use camaro, nova, chevelle? rear wheels are super deep? pic is of my wheel on a buddies truck 57
Old 09-17-2012, 11:45 PM   #5
sickred72
i can get a polished stainless tilt ( flaming river ) here locally for $580 in stock but its 33". everything i look up says 30" floor shift.
Old 09-17-2012, 11:58 PM   #6
CHIZZLER
CHIZZLER's Avatar
30" sounds about right.if the headers stick way out your going to need a shorter column to go down quicker.nice motor.
61-crew cab D-max
Old 09-18-2012, 12:26 AM   #7
Scottshotrods
We carry IDIDIT columns an have some KILLER deals on them.This is the only column out there with a lifetime warranty and all gm internal made parts.If you would like to get one let us know.We will take care of you for sure.
Justin
Scottshotrods is offline   Reply With Quote
Old 09-18-2012, 12:39 AM   #8
sickred72
Can you beat my flaming river deal?
Old 09-18-2012, 10:19 AM   #9
Scottshotrods
We can beat ANYBODYS deal on a QUALITY made column.Call me at the shop and you will see how much money you can save.
It will be worth a call!!!!!
Justin
(805)485-0382
Old 09-18-2012, 04:04 PM   #10
skip99
skip99's Avatar
look at my build page 3, went with a 32" and 30 would have been better, 28 will be about flush at firewall...it's an ididit
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
