Old 09-17-2012, 11:25 PM   #1
68_Shortbox
68_Shortbox's Avatar
Are the 4x4 rear cross-members the same as 2-wheel drive cross-members?
I need to replace both of the rear cross-members on my '68 K10 and was wondering if 2-wheel drive cross-members will fit?
Build thread for my SWB 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=447938
1968 Chevy K/10 short box fleetside (my project)
1969 Chevy Z/28 Camaro (my dad's project)
1968 Chevy C/20 long box fleetside (parts truck)
68_Shortbox is offline   Reply With Quote
Old 09-18-2012, 01:00 AM   #2
68_Shortbox
Re: Are the 4x4 rear cross-members the same as 2-wheel drive cross-members?
I am talking about the two pictured.
Old 09-18-2012, 01:02 AM   #3
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Those should be interchangable.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 09-18-2012, 06:31 AM   #4
jjzepplin
jjzepplin's Avatar
I heard that two wheel drives are wider in the back. I cannot tell you for sure as I have 4wds.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-20-2012, 02:16 AM   #5
68_Shortbox
Thank you for the responses. Is there anyone who has used or tried to use the 2-wheel drive rear cross-members on a 4x4?
Old 09-21-2012, 01:37 AM   #6
70K10Hunter
70K10Hunter's Avatar
I just built my own out of 1 1/2 x2in angle, cut to length drill holes bolt to frame then stitch weld the 1/4in over lap both sides.
70K10Hunter is offline   Reply With Quote
Old 09-22-2012, 05:12 AM   #7
68_Shortbox
Making one like that might be a good alternative if I can't find one that fits. Thanks for sharing that.
Old 09-22-2012, 03:56 PM   #8
70K10Hunter
I can't see the rear crossmembers being different between 2 and 4 WD the frame is the same width and you are not dealing with any steering components. It shouldn't even matter if it is the four link setup.
