Old 09-18-2012, 07:13 AM   #1
jstar
bagged rear axle help
i am restoring a 67 c10 and i am putting baggs on it. This is my first ever bagged truck. So far its coming along really well. without the baggs installed and the frame layed out my headers are 1/4 inch from the ground. where I am having trouble is the rear end. The truck has the normal 2 link arms where the stock coil springs were(thats where i am mounting the bags) i have a 12 bolt chevy rear end that i swapped out. My question is this, i see all these trucks that have a wish bone. Do i have to install one of these? also the stock rear end had like a track bar that only went from the diff to one side of the frame. this 12 bolt does not. do i need to fab something to make up for this difference.
that being said im not looking to do anything crazy with my set up, meaning all the motion i want in my truck is front/back/ and layed out.
CAN YALL HELP?
jstar is offline   Reply With Quote
Old 09-18-2012, 09:00 AM   #2
ZUBZ
ZUBZ's Avatar
Re: bagged rear axle help
I wish I could have helped but I am still learning and also going to be bagging my truck....
ZUBZ - C10 "GUS" - JOHANNESBURG, South Africa
My 1970 C10 Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=542560
ZUBZ is offline   Reply With Quote
Old 09-18-2012, 11:20 AM   #3
Pro Performance
Pro Performance's Avatar
When bagging these truck, it is a good idea to go with an adjustable trac-bar to help center the rear end from the new ride height. A longer bar also helps with less left-to-right movement as the suspension travels.
Porterbuilt makes one that is adjustable, and goes from the frame to the opposite side trailing arms.
http://www.azproperformance.com/63-7...c-Bar-Kit.html
Pro Performance is offline   Reply With Quote
Old 09-18-2012, 11:58 AM   #4
jstar
thanks alot!! thats excatly what i was lookig for. will i need to run a wish bone? or an upper 2 link?
Old 09-18-2012, 12:00 PM   #5
PGSigns
PGSigns's Avatar
You are going to have to add the track bar to the truck. It is want centers the rearend in the truck and keeps it there. The Porterbuilt bar is as nice as you will find.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-18-2012, 12:01 PM   #6
PGSigns
PGSigns's Avatar
Nope the track bar is all you need with the stock trailing arms.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 09-18-2012, 12:03 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
If you are on factory trailing arms,... the adjustable track bar from Porterbuilt is all you need.
Are you using drop coil springs and drop shocks also?
Keith
Convert to disc brakes.
Old 09-18-2012, 01:08 PM   #8
jstar
i havent gotten to the shocks part. i am going to place bags on there and then see what i need to fab from there
Old 09-18-2012, 03:06 PM   #9
ZUBZ
ZUBZ's Avatar
Good advice guys..
Old 09-18-2012, 03:25 PM   #10
tubbedII
needs more $$$
tubbedII's Avatar
You'll definitely want to relocate the shocks back there as they'll be laying pretty flat in the stock location. If you have some fab skills, there's a good write up on how to do it.
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 09-19-2012, 09:42 PM   #11
jstar
i put the motor and cab back on.. my headers are laying on the ground. im sure i could go lower but the headers are dragging.. any advice?
Old 09-19-2012, 09:44 PM   #12
lolife99
lolife99's Avatar
Shorty headers.
(3/4 length)
Keith
Old 09-20-2012, 10:16 AM   #13
Officer68
I'm running the Porterbuilt track bar, centers the rear end, 12 bolt truck, and looks nice at that. I currently have the header at the ground issue, the pavement has leveled them off nicely though...........yes I need shortys
Officer68 is offline   Reply With Quote
