Old 09-18-2012, 09:07 AM   #1
superlifted
superlifted's Avatar
Worth It.
I just rebuilt my th 350 and am wondering if I should have scrapped it and went with a th400. Is the fuel savings worth it? I have 3/4 ton axles with 4:11 gears and 35 inch tires and a 355 V8.
superlifted is offline   Reply With Quote
Old 09-18-2012, 09:41 AM   #2
rsavage
rsavage's Avatar
Re: Worth It.
A TH 350 and a TH400 both have 1:1 final drive ratio so there would be no fuel savings as the 400 is not an OD transmission. A 700R is an OD.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 09-18-2012, 10:11 AM   #3
jjzepplin
jjzepplin's Avatar
Re: Worth It.
If you have a 4wd then the th400 may require a different t-case or modification to your existing one. Also take a few more ponies to get going. I have a 406 700r4 and 205 and am very happy with results. You can always sell the th350 and get a 700r4. Or you could go for bigger and get a 4l80e with a th400 t-case and have bulletproof overdrive. Either case is pricey though..
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-20-2012, 02:06 AM   #4
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Re: Worth It.
All else being equal, you should get better mileage with the th350 as there is more parasitic loss with a th400 than a th350.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 09-20-2012, 04:11 PM   #5
Firebirdjones
Re: Worth It.
YEP,,,,and the 350 has a slightly better 1-2 gear ratio to get moving (2.52/1.52 vs 2.48/1.48)
Hard to beat the durability of the 400 though if that's what you are looking for.
Firebirdjones is offline   Reply With Quote
