Old 09-18-2012, 11:54 AM   #1
tx512
Spindle to use with least amount of GRINDING???
Hey guys I need some help on which spindle to buy that wont require alot of grinding. This past weekend I took off the 22's off and noq Im running 8" ralley wheels. 235/70/15 up front and 275/60/15 rear
2.5" or 3" doesnt seem like that big of a deal. I'm only planning on going 4" drop up front by way of cutting the spring.
and I'm leaning toward a 5" flip kit
what brand do yall recommend and where to buy???
TKS in advance!!!
tx512 is offline   Reply With Quote
Old 09-18-2012, 12:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Spindle to use with least amount of GRINDING???
My guess would be a CPP Modular spindle since they are only a 2" Drop.
But they cost more than the standard drop spindle.
I would just buy a set of $219 standard 2.5" drop spindles and grind the lower control arm for clearance like everyone else that runs truck ralley wheels has to do.
Make sure your new drop spindles match the width of your front rotors.
(1" or 1-1/4" wide)
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 09-18-2012, 01:48 PM   #3
f.monroe
f.monroe's Avatar
I have had Western Chassis 2.5 inch spindles on two trucks with no grinding of the LCA's. Both trucks had the 1.25 inch rotor option. I do not know if anything changes with the light duty spindle config.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 09-18-2012, 02:17 PM   #4
tx512
Tks. I appreciate the info!!
Anyone else??
Old 09-18-2012, 02:19 PM   #5
TheSuspensionSource
Belltech is a 3" spindle. See photo 29 of their install notes http://www.belltech-store.com/extras/docs/BBGC/3100.pdf
TheSuspensionSource is offline   Reply With Quote
Old 09-18-2012, 04:42 PM   #6
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Frank
I have the light duty rotors with 2.5" Western Chassis drop spindles and 8" rally wheels. I have done zero grinding, and have had no problems with them in the 6 or 8 years I have been running that setup.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
