Oh,you can't buy that new
![]() Join Date: Apr 2000
driveshaft lengths- SWB ???
I have two, one piece, driveshafts here that are BOTH marked (by me), and i don't usually make mistakes in my labeling but here they are. These were BOTH supposedly from a SWB with TH350, but i suspect the shorter one from a 700R4 truck. ONe could also be from an older truck with 12 bolt because the pinion to center distance IS different than a 10 bolt. ANYONE with an older truck and 12 bolt?? measure for me. thanx, crossy
#1 is 52" weld to weld and 55-1/2" from center of u-joint to center of u-joint. #2 is 55-1/4"weld to weld and 58-3/4" from center of u-joint to center of u-joint.
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww ![]() 84,C10 SWB-Yella,stock 86 K10 SWB-Red, hopped up 305,4/S LOTS of Cummins trucks. |
Re: driveshaft lengths- SWB ???
My 74 SWB with a TH350 short tail(6in)/12 bolt rear has a 59.5in drive shaft measured center u-joint to center u-joint. My neighbors truck is a 84 SWB with a 700R4/10 bolt has a 55.5in drive shaft measured same way.
John 82 Chevy Silverado 350ci/TH350
| Bookmarks |
