Old 09-18-2012, 02:22 PM   #1
forestb
forestb's Avatar
old license plates
If I have a set of old black and yellow California license plates off of another vehicle that is no longer registered is there a way to get my truck registered with those plates.
forestb is offline   Reply With Quote
Old 09-18-2012, 02:33 PM   #2
maskale
Re: old license plates
call your DMV or check online, in TX we can use year of manufacture plates.
maskale is offline   Reply With Quote
Old 09-18-2012, 02:38 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Call the DMV. Have them run the numbers on the plate. They will tell you if they are cleared or not, also they will tell you what years you can use them on. They must be commercial plates. Use the DMV "callback" service when you call them, it is awesome so you dont have to stay on hold.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-18-2012, 02:39 PM   #4
mr48chev
mr48chev's Avatar
If they are truck plates. The vehicle you put them on has to match the designation on the plate.
If they are plates that were on a vehicle you had in your name so much the better.
Here, check this out.
http://apps.dmv.ca.gov/forms/reg/reg352.pdf
Old 09-18-2012, 03:41 PM   #5
oem4me
Under the YOM program you can register a clear set of plates that are correct for the year your vehicle was manufactured. Since your truck is a '62 I believe you would need a 1956 series plate (yellow plate black letters) with a 1962 sticker on it. The black plates started in 63, so technically would not be correct as far as DMV goes. I also think a lot has to do with how sharp the clerk behind the counter is and what kind of day they are having.
When I did my '66 truck, I needed two clear 63 plates in good condition with one new 1966 sticker to pass. I was turned down on the first try without the sticker. stickers you can get NOS or repro from ebay and either will work as long as the quality is high. If anything looks fishy, you will be denied. Good luck.
Old 09-18-2012, 04:32 PM   #6
forestb
forestb's Avatar
That should work fine then sense my truck is registered as a 63
Old 09-18-2012, 05:28 PM   #7
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Just got my plate at the good guys show and it was simple to get it on my truck.. If you have a smart phone, down load your state DMV address and you can check the plate right there on the spot to see if its clean.. Here in AZ if the plate is clean but has not been registered for some time the numbers can get reused on a new plate. At that point its no longer any good.
GMR-PERFORMANCE is offline   Reply With Quote
Old 09-18-2012, 07:13 PM   #8
gimmy 64
ther is a law that just passed the state senate and is waiting gov. browns sig. it is for new plates that will be made in yellow with black letters and black with yellow numbers also blue with yellow. they can be purchased through dmv for the year your original plates were. this was an article from sema or san. pretty cool
gimmy 64 is offline   Reply With Quote
Old 09-18-2012, 07:28 PM   #9
leddzepp
Moderator
leddzepp's Avatar
Have you seen what they look like? It is a great idea... except they cost a $$ and you can tell they are not original.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-18-2012, 07:49 PM   #10
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Here's mine!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
