Old 09-18-2012, 07:30 PM   #1
brycerowdy
brycerowdy's Avatar
Project "Uncle John" 1969 Chevy c20
Lets get down to the point. I got this truck as a Christmas present in 2011. Since that I have done a little work to it. I have got the 396 running,and cleaned out the interior.
1970 Chevy K10 "Goldie" 350/TH350 - Current Project
2007 Audi A4 Quattro S-Line - Daily
brycerowdy is offline   Reply With Quote
Old 09-19-2012, 08:30 PM   #2
brycerowdy
brycerowdy's Avatar
Re: Project "Uncle John" 1969 Chevy c20
I haven't worked on the truck in a while but I will keep the 396 but will put in a 700R4.
Old 09-19-2012, 09:06 PM   #3
Tinkermc
well I like your santa much better than mine. Welcome to the forum
Tinkermc is offline   Reply With Quote
Old 09-20-2012, 10:08 AM   #4
brycerowdy
brycerowdy's Avatar
Thank you
Old 09-21-2012, 10:39 AM   #5
truckzilla
truckzilla's Avatar
I've been following your dad's build of Fred and look forward to seeing what you do with your 'farm truck'. How's that 396 running? I'd have to agree on the 700R4. Do you know what your rear gearing is by chance? My dad put a 700R4 in his '70 and it really dropped his highway RPMs in overdrive more than he wanted due to his truck having such low (numerically) gearing in the pumpkin. And post more pics if you're able. Good luck and welcome to the gang!
truckzilla is offline   Reply With Quote
Old 09-22-2012, 12:23 PM   #6
brycerowdy
brycerowdy's Avatar
Truckzilla the 396 runs great the only problem right now is that it won't idle. I think the rear gears are 4.10. and Cool!
Old 09-24-2012, 10:04 AM   #7
brycerowdy
brycerowdy's Avatar
Ok i just got a new laptop so i will post some more pics tonight.
Old 09-30-2012, 10:10 AM   #8
brycerowdy
brycerowdy's Avatar
Cupholder!!! Thanks Larry!
Old 09-30-2012, 08:47 PM   #9
brycerowdy
brycerowdy's Avatar
I got the cupholder installed and the 396 at an idle.
Old 10-01-2012, 10:10 AM   #10
brycerowdy
brycerowdy's Avatar
Ok, so I drove the truck up and down the driveway on Saturday and the 396 was awesome. I need to get a tranny shift module put in so it will shift out of first gear. Other than that, the truck has been awesome.
Old 10-01-2012, 11:17 AM   #11
truckzilla
truckzilla's Avatar
A 4.10 rear gearing should go very well with the 700R4! If the trans is stuck in first gear, it sounds like it maybe the module is stuck in failsafe mode. That lets the driver limp home rather than leave the vehicle stranded. A transmission shop should be able to correct that I believe.
Old 10-01-2012, 04:54 PM   #12
GMCJOE
GMCJOE's Avatar
I would love for santa to get me a present like that. But for now, I will settle for buying my own parts. Hope that modulator does the trick for ya. Nice truck, looking forward to more pics.
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 11-02-2012, 01:08 AM   #13
68 TT
Still plays with trucks
68 TT's Avatar
It could just be the vacuum hose to the vacuum modulator on the transmission is leaking or fell off. Happens quite often.
Without that line connected and getting vacuum to the trans it will not shift out of first gear. Worth a look before you go buying parts.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-02-2012, 08:08 AM   #14
brycerowdy
brycerowdy's Avatar
Ok I'll look tonight.
Old 11-02-2012, 11:19 AM   #15
truckzilla
truckzilla's Avatar
I wasn't aware that a 700R4 had a vacuum modulator.
Old 11-02-2012, 11:24 AM   #16
truckzilla
truckzilla's Avatar
When my 700R4 did that, there was some issue with the electical connection like water had gotten in it or something like that. That was on a '96 model though. It might be the TV cable needs adjusting or some other small item.
Old 11-02-2012, 11:46 AM   #17
truckzilla
truckzilla's Avatar
Thumbs up Re: Project "Uncle John" 1969 Chevy c20
On another board, one poster responded to the same problem someone else was having with this:
First check tour TV cable and make sure its adjusted right. Next you will have to pull the valve body and check the TV valve and the shift valves and make sure nothing is sticking. Also your governer valve could be stuck. Pull the governor and look at the gear and make sure its not chewed up. Also hold the governor so the gear is pointing up and move the weights open and closed and see if the valve moves up and down.
With my issue of the trans sticking in first gear, I think because of the year of it, it wasn't a 700R4 after all but the electrically controlled version of it known as the 4L60E. So the electrical plug and module matter may not even apply for you if your's is a pre '93 transmission.
And from another site, they say:
The governor on a 700R4 automatic transmission helps control gear shifts. If your 700R4 is stuck in first gear and will not upshift, you can access the governor through the governor housing cover on the transmission body.
Read more at:
http://www.ehow.com/how_8740017_remo...ing-700r4.html
Best of luck!
Larry
Old 11-02-2012, 07:06 PM   #18
brycerowdy
brycerowdy's Avatar
Larry it is a T400 trans
Old 11-02-2012, 07:23 PM   #19
truckzilla
truckzilla's Avatar
I'm sorry. Just ignore all that previous stuff then! A TH400 is a beefy trans! I had that behind my '88 crewcab Chevy dually with a 454. I couldn't break that trans if I had too! But it sure needed an overdrive gear something bad!
Maybe your problem is something as easily solved by checking your vacuum lines or maybe a funky modulator! Anyway, I hope you get it resolved so you can get it going good!
All the same, best of luck.
Larry
Old 11-02-2012, 10:33 PM   #20
White70C20
White70C20's Avatar
I'm curious to see what RPMs you run with the th400 and 4.10 gears. My '70 C20 just seems to run kinda high rpms at 55-60 mph. I would like to put a 700r4 in it, but I also want to keep it as original as possible.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 11-04-2012, 03:20 PM   #21
brycerowdy
brycerowdy's Avatar
It will be a while till I put in the 700r4
Old 11-27-2012, 10:48 PM   #22
brycerowdy
brycerowdy's Avatar
Old 12-04-2012, 11:01 AM   #23
brycerowdy
brycerowdy's Avatar
So as you can see i moved the truck outside for the winter to make room for my dads car. So for now there wont be many updates till spring time.
Old 12-04-2012, 12:54 PM   #24
truckzilla
truckzilla's Avatar
Not that you don't have anything to do in Colorado in the winter time!
When you're not out tearing up the slopes or jumping snowmachines, you can consider this to be planning and dreaming time!
Old 12-04-2012, 07:42 PM   #25
brycerowdy
brycerowdy's Avatar
Oh, I didn't think of that! I guess it is time to get plans made up!
