Old 09-18-2012, 11:29 PM   #1
rcbildr
rcbildr's Avatar
Trailing Arm Crossmember???
I started work again on my 63 chevy today. I'm in the process of converting it to 4x4. I think I might have to remove the crossmember the trailing arms mount to. I was wondering if that was something worth saving....figured I would ask before I start cutting it up to remove it. Thanks!!!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
