Old 09-19-2012, 12:53 AM   #1
jess66chevy
jess66chevy's Avatar
Speedo NOT WORKING???
I recently had my 350 transmission rebuilt and now my speedometer doesn't work. It was working before I replaced the transmission. I even replaced the speedometer cable and still no luck.
Could it be the transmission speedometer unit (I dont exactly know what its called, but it is the little silver unit on the transmission in the picture)???
Any thoughts..........?
jess66chevy is offline   Reply With Quote
Old 09-19-2012, 10:01 AM   #2
geezer#99
geezer#99's Avatar
Re: Speedo NOT WORKING???
That silver thing is a ratio adaptor. It screws onto the speedo. Unscrew it and hook your speedo cable back up without it and see if your speedo works.
geezer#99 is online now   Reply With Quote
Old 09-20-2012, 01:10 AM   #3
jess66chevy
Thanks for the reply & advice! What the heck is the "ratio adapter" and what does it do?
Old 09-20-2012, 10:05 AM   #4
geezer#99
geezer#99's Avatar
It corrects your speedometer. If you swap trannies and your speedometer is not accurate that little gizmo makes it accurate. I'd tell you it's all magic but I'll give you a link instead.
http://www.transmissioncenter.net/sp...____va.htm#350
