Old 09-19-2012, 01:29 PM   #1
Red65C10
Red65C10's Avatar
Converting to disc brakes
Looking for any input, suggestions etc. I bought this front end from a 78 to go under my 65. Need info/ideas on master cylinders, boosters, lines or anything else you would like to add.
Thanks,
Name:  New Image.jpg
Billy
65 C10
............................... ____
................ ________-|___\____
.;.;;.:;:;.,;.|__(O)___|____/_(O)|
_______________________________
P.S. Send truck money !
Red65C10 is offline   Reply With Quote
Old 09-19-2012, 02:17 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Converting to disc brakes
just use the a-arm, spindles,rotors and calipers on that front susp. should bolt up just fine. best if you get the stuff from the donor you got the discs from but you can go through the vendors and get all that. dont forget to rebuild suspension while its apart.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-19-2012, 10:07 PM   #3
Red65C10
Red65C10's Avatar
Thanks Clyde, Im gonna do the whole cross member and all. Pulling the motor will give me a chance to take care of some other things with that.
Billy
65 C10
Old 09-20-2012, 01:26 AM   #4
Captainfab
60-66 Nut
To keep things simple just use a master cylinder for the '78. Hopefully you grabbed the proportioning valve also. For the booster, that all depends on how you want to mount it to your firewall. The booster bracket I sell does not require drilling any more holes in your firewall. Other boosters and mounts require drilling holes to mount.
It looks like you got the entire steering linkage as well. I would suggest using the '78 idler arm, but you will have to drill 2 new holes to mount it. Using the complete steering linkage, simplifies the installation and when it comes time to buy replacement parts it is easier to remember whar year if truck to ask for parts for.
Old 09-20-2012, 09:51 AM   #5
tincan1966
tincan1966's Avatar
There are LOTS of threads on this topic.
tincan1966 is offline   Reply With Quote
Old 09-20-2012, 10:25 AM   #6
Chevy Fleetside
Chevy Fleetside's Avatar
This is prettymuch it. Only differnce is this was a 3/4 ton truck but they will be the same. http://67-72chevytrucks.com/vboard/s...d.php?t=357610
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 09-21-2012, 12:44 AM   #7
Captainfab
60-66 Nut
This is probably the most complete thread on disc brale conversions. Although there are a couple more in the '60-'66 FAQ section.
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
Old 09-21-2012, 09:56 AM   #8
Red65C10
Red65C10's Avatar
Thanks Guys, Great info. John the link is very helpful !
Billy
65 C10
