Alarm triggered door popper ???
Hi I think the (-) alarm truck popper wire has to low of a signal to make the door popper work.
The multimeter shows a current but the popper won't pop.? If I hold the popper's wires directly to the battery it works fine... Need help to make this work.....? ![]() ![]()
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
I am a Referee of life.
Re: Alarm triggered door popper ???
The ground may not be making well.It needs to be solid to clean metal.
But,from what you describe,there may be a voltage drop thru the switch.You may need to run a relay to get enough current to "pop"it.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Yep, you gotta have a relay for each door. An a/c type relay would work or you can by a harness with relays from AVS. I'm using the AVS shaved door kit with 60 lb door pushers. Works great.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb ![]() |
