Old 09-19-2012, 05:32 PM   #1
sjarrett71
sjarrett71's Avatar
Gas Tank Pressure
My carb is off the engine getting rebuilt and the fuel line is obviously disconnected. I came home from work to a puddle of fuel under my truck and popped the hood. There was fuel pooled up on my intake and fuel coming out of the fuel line. I took my gas cap off to the normal sound of pressure escaping and the fuel stopped running out of the line. It is a new gas cap. My truck is a 72 with a 350 and the rochester carb. All of the fuel lines are new as are the vacuum lines for the EGR and the lines running to the charcoal canister. Do I need a vented gas cap or is this normal? I have unscrewed the gas cap so pressure won't build and hopefully I won't lose anymore gas until I get the carb installed. Also, is it ok for the system to build pressure like this when I reinstall the carb?
-Scott-
sjarrett71 is offline   Reply With Quote
Old 09-19-2012, 06:20 PM   #2
cdowns
cdowns's Avatar
Re: Gas Tank Pressure
you have a venting problem with your gastank// a 72 has a vent line from the tank up into the passenger side door pillar then to the charcoal cannister// many guys just block it off and cause themselves this problem
Old 09-19-2012, 06:37 PM   #3
sjarrett71
sjarrett71's Avatar
Any common areas to look for the problem? Like I said, every piece of rubber hose I could find has been replaced. It seems like there should be plenty of areas for the pressure to vent without it pushing fuel out of the line.
-Scott-
Old 09-19-2012, 06:55 PM   #4
cdowns
cdowns's Avatar
find the vent line from the gas tank that goes up into the passenger side rear door post// and follow it
