Old 09-19-2012, 10:37 PM   #1
Joe69C10
Joe69C10's Avatar
Rear end options for my 87?
Hey all...I have an 87 C10 with stock 10 bolt. Its 1 wheel wonder and has god awful gears in it. I don't think I've used overdrive in a long time!
I was looking around local classifieds to see if I could find someone selling a 10 bolt posi rear, and if I'm lucky maybe find one with some decent gears in it.
Are there any other options as far as rear ends that would fit in the 80's body style trucks?
What do you all think is the most economic option for posi and 3.42 or 3.73 gears?
Joe69C10 is offline   Reply With Quote
Old 09-20-2012, 08:55 AM   #2
one low c10
Re: Rear end options for my 87?
I am currently swapping in a rear from a 96 9c1 police car. it has 3:73 and a limited slip in it. took it to a local shop that builds race car chassis (circle track dirt cars) and for $75 bucks he welded on my perches, shock mounts and set the pinion angle since I flipped the axle over the leafs. I picked up the rear off a friend for 50 with disc brakes and all
one low c10 is offline   Reply With Quote
Old 09-20-2012, 09:28 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
I have a 3.4 rear gear locker seems even better on gas since repairing the gas line lol
not sure if that fits tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 09-21-2012, 11:14 AM   #4
Joe69C10
Joe69C10's Avatar
Thanks for the info. Do you know if this is a spring style posi or G80 Eaton style posi? I bet they hold up pretty well being they ran them in the cop cars.
Old 09-21-2012, 11:25 AM   #5
stroker87
I swapped from a 10 bolt to a 12 bolt out of a 70's truck, my brake backing plates bolted right up no mods needed
stroker87 is offline   Reply With Quote
Old 09-21-2012, 10:21 PM   #6
rs74
rs74's Avatar
My 85 has a 12 bolt in it that I swapped out of my old 83 shortbed. But I am not sure what it originally come out of. It bolted right in. Did half tons come out with a factory 12 bolt?
rs74 is offline   Reply With Quote
Old 09-21-2012, 11:03 PM   #7
sierra4x4
sierra4x4's Avatar
Look for a posi out of a 71-81 Camaro, 73-77 Chevelle, 71-90's Full size Chevrolets. That is were you will get a good posi not the truck gov-lok. Most of these used the 8.5 10 bolt. Just remember that 2.56 and down is a 2 series and 2.73 and up is a 3 series. you can use the 2 series with a ring gear spacer if you want 2.73+ gearing. All half tons got 10 bolts in 1982. 1981 and older used the 12 bolt.
sierra4x4 is offline   Reply With Quote
Old 09-22-2012, 07:29 AM   #8
wraprail
wraprail's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=544039
My 2 cents
wraprail is offline   Reply With Quote
Old 08-26-2013, 11:57 PM   #9
iceship
Ha Joe... so how did if fit inside the truck... is it the same width. I have a 93 roadmaster wagon I have just setting around. ..
iceship is offline   Reply With Quote
