09-20-2012, 02:12 PM | #1 |
What's the best replacement AC Compressor?
Ugh, I thought I had a good plan in place to replace my leaking junk Harrison rebuild AC compressor with one of those new aluminum Sanden compressors using R12, but after calling Vintage Air to get the correct part number, they told me I would need to replace every piece of my AC system first. They say that their 508 pump doesn't put out enough pressure to work with a factory GM AC system. Have any of you guys dealt with this successfully and what would you recommend for me to do.
Thanks all, 72 Chevy K10 350 with Factory AC |
09-20-2012, 02:26 PM | #2 |
Moderator
Re: What's the best replacement AC Compressor?
use a pro6ten compressor from old air products. they look like an oem harrison A6 compressor, but are far more efficient and they bolt right into the factory brackets and use the factory hoses. they are around 350 but they are brand new and will not leak like all the rebuilt oem ones out there.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
09-20-2012, 06:47 PM | #3 | |
09-20-2012, 07:28 PM | #4 |
Moderator
good to hear! you will not be disappointed. i had one on my last truck and it worked great.
