Old 09-20-2012, 02:45 PM   #1
Fesser
Fesser's Avatar
Utility bucket vs. Sport bucket mounting
The more I search, the less I know.
My 70 came with utility buckets. They were trashed.
Was planning on putting in sport buckets. Found some 73's and started searching to see if they would bolt in. Now I am not sure that even the stock Sport buckets will bolt in.
Question - Did utility equipped Blazers still have the same mounting holes as Sport bucket Blazers? How about front bench seat holes? Did Chevy provide holes for all options or just for what the truck was built with. Thanks.
Fesser is offline   Reply With Quote
Old 09-20-2012, 05:17 PM   #2
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Re: Utility bucket vs. Sport bucket mounting
The mounting holes are all the same as far as I know. I had a set of utilities that I never installed in my old blazer and the mounting looked the same as my current blazer. I believe you can mount a bench out of a PU without any issues too, you'll just have a few extra holes in the floor.
I don't believe your 73's will bolt in.
You could try removing the upper seat from the mounting frame. I just swapped my driver's seat and passenger seat because I was getting the gangsta lean in the drivers seat. It was a simple bolt and unbolt. You may find the same with utility vs sports.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 09-20-2012, 06:15 PM   #3
jaros44sr
jaros44sr's Avatar
The distance between the feet of the utilities and sports are differant....utilities are about 15 1/4".....sports are about 12 1/4" front to back, but you can drill holes and build the backing plate...not that hard, just a plate with some nuts welded to it
Mine came with sport, i am putting utilities in, no holes in the floor for the back feet
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-28-2012, 10:23 AM   #4
blue70k5
blue70k5's Avatar
Unfortunately the 73+ brackets are different from either of the 69-72 versions as well... I've tried!
blue70k5 is offline   Reply With Quote
