Old 09-20-2012, 03:02 PM   #1
turbo350
suburban 1/2 ton vs 3/4 ton weight
Obviously towing capacity is more, but how much more curb weight is a 3/4 ton late '70s 2wd sub vs an equal year 2wd 1/2 ton suburban? Both are 454 equipped.
turbo350 is offline   Reply With Quote
Old 10-18-2012, 05:30 PM   #2
gmachinz
Re: suburban 1/2 ton vs 3/4 ton weight
I had my 1990 3/4 ton 2WD burban on some scales and it weighed in at 7200lbs. and its a 454/th400 equipped truck.
gmachinz is offline   Reply With Quote
Old 10-18-2012, 06:27 PM   #3
Edahall
My book says that a 1989 Suburban weights as follows:
1/2T 2WD - 4433
1/2T 4x4 - 4675
3/4T 2WD - 4816
3/4T 4x4 - 5128
A 454 would add a couple hundred more pounds.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 10-19-2012, 09:30 AM   #4
OutlawDrifter
wow, i was thinking more in the 6k range.....that makes me feel like my z/28 is a brick at 3600lbs, haha.
i read somewhere the other day that 4wd k5's are in the 4k range too.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 10-19-2012, 09:44 AM   #5
gmachinz
Lol...yeah those factory manual numbers have to be off.....recently we took a load to the dump with a 3/4 4x4 Silverado K20 and empty with two passengers it weighed in at 6820lbs. So with my 90 Suburban weighing in at 7200lbs is probably correct too. And with 8-9 mpg I'd believe it! Lol
Old 10-19-2012, 10:52 AM   #6
68Timber
I know the pieces fit
68Timber's Avatar
I haven't weighed either of mine, but my 2wd is supposed to be around 4300 and my 4x4 around 5300. The 4x4 does have the heavier 6.2, a small block 4x4 truck should be closer to 5000.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-20-2012, 11:28 PM   #7
kwin
kwin's Avatar
1/2T 2WD - 4433
1/2T 4x4 - 4675
3/4T 2WD - 4816
3/4T 4x4 - 5128
I have weighed both my half tons, and if that is dry weight ( no fuel) they are right on the money.
Keith Winsor
www.ramsaywinsor.com
kwin is offline   Reply With Quote
