Old 09-20-2012, 03:41 PM   #1
Jacob.
Fuel lines and 5.3 ?
Alright, so i've been looking to get a 67-72 pick up but i'd really like to have the reliability of a lsx based engine .. So I have some questions. I'm trying to get a budget worked out for what it would cost me.
Fuel line:
I've found it to cost about $350 -> $400 depending on if its return or returnless to the stock tank. I'll write out my layout, let me know if this seems correct.
Returnless:
20 Ft Braided
Feed Line:
Tank(Russell#610160 or Russell#612180) -> Hose -> (Russell#670470+Russell#610020)Walbro 255(Russell#670470+Russell#610020) -> Hose -> (Russell#640850+Russell#610020)Wix33737 Regulator(Russell#640940+Russell#610020) -> Hose -> (Russell#640850+Russell610020) Fuel Rail
Return Line:
Wix33737 Regulator(Russell#640860+Russell#610020) -> Hose -> Not sure how it will return to tank yet. Seen couple ideas.
Return Style:
20 Ft Braided? maybe more
Feed Line:
Tank(Russell#610160 or Russell#612180) -> Hose -> (Russell#670470+Russell#610020)Walbro 255(Russell#670470+Russell#610020) -> Hose -> (Russell#640850+Russell#610020) Fuel Rail.
Return Line:
Fuel Rail(Russell#640860+Russell#610020) -> Hose -> Not sure how it will return to tank yet. Seen a couple ideas
I think what I have here is pretty accurate to what it would be like using Russell AN -6 line and fittings.
Also, could you help me get a list of things I should be able to get along with my pullout? I was quoted for 1400 for a 80k mile 5.3 without tranny for complete pullout which included the engine, intake, accessories, manifolds, computer.
My list:
5.3l w/ 80k
Accessories - Starter, alternator, ?
Computer
Wiring harness
Intake
Manifolds
DBW pedal if applicable
is 1400 a good price for a complete pullout? Is there a cheaper way to run fuel lines? Thanks.
Jacob. is offline   Reply With Quote
Old 09-20-2012, 03:56 PM   #2
Kim57
Kim57's Avatar
Re: Fuel lines and 5.3 ?
I think you can save a lot by not running braided line all the way. I used braided to connect to the tank, filter and regulator but used 3/8 hard line every where else.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-20-2012, 04:02 PM   #3
Jacob.
Kim
Would I still need to use the Russell AN fittings? Or do they connect in a different way? Whats killing is the price of all the connectors.
Old 09-20-2012, 04:46 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
there would still be fittings adapting the steel line to the braided, and for the fuel rail and such, but you save a good amount taking out 8ft of braided hose and using $8 worth of brake line instead.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-20-2012, 04:54 PM   #5
Jacob.
Ok. I'll go over and figure out how much using hardlines and some braided. Thanks
Old 09-20-2012, 08:42 PM   #6
Jacob.
Alright this is what I have come up with:
Braided SS $460.04 + 12.95 shipping
Hard Line $397.59 + 12.95 shipping
Here's the breakdown for them.
Braided SS
Feed Line:
Russell 614226 19.95
Russell 612180 29.95
Braided Line
Russell 610020 7.95
Russell 640470 11.95
Walbro 255 Pump
Russell 610020 7.95
Braided Line
Russell 610020 7.95
Russell 640850 15.95
Wix 33737 Reg.
Russell 640940 11.95
Russell 610020 7.95
Braided Line
Russell 610020 7.95
Return Line:
Wix 33737 Reg.
Russell 640860 14.95
Russell 610020 7.95
Braided Line
Russell 639200 11.95
Russell 612460 28.99
Aswell as:
Earls Performance Aluminum Fuel Line 10ft. ( I really only need like a foot -.-) 10.95
Walbro 255 external 112.95
Wix 33737 Regulator 39.95
Summit Braided SS hose 20 ft. 74.95
Now for Hardline:
Feed:
Sum 220139 .59
Hardline
Sum 220139 .59
Russell 670470 11.95
Walbro 225
Russell 610020 7.95
Braided Line
Russell 610020 7.95
Wix33737 Reg.
Sum 220139 .59
Hardline
Sum 220139 .59
Russell 660460 4.95
Return:
Wix 33737 Reg.
Hardline
Sum 220139 .59
Russell 661460 5.95
Sum 220139 .59
Hardline return
Summit Aluminum Fuel Line 25' 18.95
Summit 37* Flare Set 29.95
Summit 3' Braided SS 14.95
Summit Mini Tubing Cutters 7.95
Walbro 255 External 112.95
Wix Regulator/Filter 39.95
My initial numbers were wayy off because it was pretty late haha. This is more accurate i think. Unless I'm doing something here HUGELY wrong.. :S..
Old 09-20-2012, 10:10 PM   #7
clinebarger
Ive been running Nylon fuel line for the last year or so on all swaps. Cheap & Easy. http://www.fuelsender.com/fuel_line.html, Here's the same kit kit I have for $175. http://www.wayfair.com/S.U.R.-and-R-...FdSPPAodFzQAnw
Has everything to do returnless & return style fuel systems.
The Nylon fuel hose is easy to kink....So be carefull.
clinebarger is offline   Reply With Quote
Old 09-20-2012, 11:18 PM   #8
Jacob.
That's sooo funny. I actually just started looking at this stuff.. Like half an hour ago
Old 09-21-2012, 01:37 AM   #9
Jacob.
If anyone is familiar with the KP1200 set up. Could you let me know if I have the right setup for this?
Feed Line:
Fuel Tank -> K100 -> Nylon hose -> K075 -> Walbro255 -> K075 -> Nylon Hose -> KP020 -> Wix 33737 -> Dorman 800-155 -> Nylon Hose -> KP020
Return Line:
Wix 33737 -> KP040 -> Nylon Hose -> K050
I'm mostly worried about the K075's fitting into the Walbro 255.
If this works I'll be right around $350 for all the fueling system.. Lines, connectors, pump and regulator.
Old 09-21-2012, 07:35 PM   #10
clinebarger
Feed Line:
Return Line:
You will need 2 Walbro 128-3012 "Bundy" style fittings for the pump, Then the KP020 quick disconnects will plug right in
Old 09-21-2012, 08:29 PM   #11
Jacob.
What is the difference between the Kp020 and Kp030?
3/6-5/16 Straight push quick connect.. It seems misleading.. can this be used as a kp020 and a kp040?
If so the kit comes with every BUT the 128.3012 bundy.
EDIT: How does my complete pullout list look?
For 1400 he said it was a "complete change over" without tranny 1400.
80k 5.3
intake
wire harness
throttle body
exhaust manifolds
coil packs
mech or electric fans
all accessories which should include; starter, alternator, power steering pump, the belt, AC compressor. (I won't be running AC, but might as well get it)
DBW Tach, Harness, Pedal
Computer
All Sensors?.. So MAF and O2
All plugs
PCM
Oil pan
Fuse Box
Fuel rails
Power steering res
Radiator Hoses
ECU
Pulleys
Radiator?( has anyone fit or used one from a silverado?)
Let me know how close my list is.
Old 09-22-2012, 11:13 AM   #12
eagleuh1
eagleuh1's Avatar
I used aluminum hardlines with tubing nuts to AN 90' elbows out of my Boyde tank with internal pump going to the filter/regulator, which I mounted on the tank. Used the summit AN quick connects to the filter reg. Then short push in to filter/reg dischard with braised on AN fitting. Short section braided stainless to slip on An onto steel hardline up to engine compartment. Another short section of Braided stainless and Russell An to quick connect on fuel rail. Works great.
eagleuh1 is offline   Reply With Quote
Old 09-22-2012, 06:37 PM   #13
clinebarger
The 3/8-5/16 fittings are no good to you on a swap, So it does look like you need an extra KP020.
I dont use external fuel pumps....So this uses more fittings than Im used to.
Old 09-26-2012, 03:01 PM   #14
eagleuh1
eagleuh1's Avatar
What tank are you planning on using?
Old 03-31-2013, 05:34 AM   #15
slamed67
slamed67's Avatar
ok. i have an 01 5.3 vortec with the return style fuel rails.. and a boyd welding 340 stealth efi fuel tank.. im looking for a list of fittings lines and filter. can anyone please help a guy out?
slamed67 is offline   Reply With Quote
