09-20-2012, 05:19 PM | #1 |
Hood hinge???
Both my 78 Jimmy and 80 Scottsdale hoods will not sit flush with the fender closest to the cab and cowl area. Is this a problem with the hinges or springs? I've noticed quite a few 73-80 trucks with this problem. Why doesn't the 81-87 trucks have this problem? Can I use hinges from the 81-87 on a 73-80? I did a thread search and didn't see anything on this topic (which I found strange) so sorry if this is a duplicate. Thanks for any help!
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
09-20-2012, 06:39 PM | #2 |
Re: Hood hinge???
im also having this problem......
09-20-2012, 07:51 PM | #3 |
Re: Hood hinge???
have you tried adjusting the hinge?...the holes are slotted
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
09-20-2012, 08:15 PM | #4 |
Re: Hood hinge???
It is not a hinge/hood adjustment, definitely the hinge is hooped. I just had the same issue, got a donor set of hinges off the parts truck, hood is now perfect.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
12-14-2013, 06:34 PM | #5 |
Re: Hood hinge???
I'm having this problem too. My old stock hinges were literally shot so I bought new ones with new springs from LMC and still it wont sit down all the way at the cab on either side. I'm having this problem too. What do you mean by the hinge in "hooped" please?
12-15-2013, 10:48 AM | #6 | |
Re: Hood hinge???
It doesn't happen on the 81-87s because the hinge is completely different. They do not use the compound hinge that lifts and tilts at the same time.
They have a shorter hood with a "fixed" cowl and a "single pivot" hinge. The spring assist which holds it open, is a separate unit and theoretically doesn't even have to be there.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
12-15-2013, 01:36 PM | #7 |
Re: Hood hinge???
use of Sea Foam Deep Creep lubricant might help
