Old 09-20-2012, 10:18 PM   #1
jsdoyle
jsdoyle's Avatar
Exhaust Issues
I have headers off my 350 that go into 3 inch pipes with Flowmaster 40's. It is pretty loud and a friend of mine told me that it sounded like my donut gaskets or header gaskets need replacing.
I got to looking at my headers at the engine and noticed a hodge-podge of bolts/nuts holding on the headers. See the two pictures attached. There appear to be two different size bolts, the outer ones larger than the inner bolt heads. Also the left front looks like a headless bolt with a nut tightened down.
Kind of inconsistent. I'm wondering, is there normally a standard size for all of the holes that attach the headers to the head?
The left side seems louder at the engine and it's possible the header gaskets are not sealing like they should.
Some of the bolts are rusted and I'd like to make them more consistent in appearance for both sides.
Any suggestions?
Thanks,
Scott
jsdoyle is offline   Reply With Quote
Old 09-20-2012, 10:21 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Exhaust Issues
Those inner bolts are typical header bolts. The smaller heads make them easier to use. Who knows what that stud was for on the passenger side.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 09-20-2012, 11:19 PM   #3
MOTOIMPAIRED
MOTOIMPAIRED's Avatar
Re: Exhaust Issues
It is real simple to replace the header gasket and put in some new bolts. Just replace the bolts one at a time but dont tighten them all the way. Then just drop down the new gasket and tighten all the bolts. Done deal!! I also spray mine with copper coat.
MOTOIMPAIRED is offline   Reply With Quote
Old 09-21-2012, 01:11 AM   #4
Captainfab
60-66 Nut
Re: Exhaust Issues
Agreed. Those inner bolts with the smaller heads are actual header bolts. I see you have what looks like the copper header gaskets, and I don't see any obvious signs of leaking. Have you tried tightening them a little? One of the biggest mistakes made with headers, is guys over tightening the bolts, because they think they are leaking. More often than not, this just warps the header flange, and you will never get them to stop leaking without removing the headers and straightening the flanges. This is why so many guys hate headers. I would also check your collector gaskets. Also check the little lip on both the header and the exhaust pipe and make sure it is not cracked or missing.
Old 09-21-2012, 08:37 AM   #5
jsdoyle
jsdoyle's Avatar
Re: Exhaust Issues
Thanks for the tips!
So, I guess I need to pull a couple of the different sizes and go get some stainless replacements. Is there a source for chrome bolts or would stainless be the best choice?
Old 09-21-2012, 03:02 PM   #6
ChuckW
ChuckW's Avatar
Re: Exhaust Issues
A regular header bolt kit from your local hot rod shop will work great... Use some anti seize (Just a little) on your new bolts. They will thread in easier AND they will actually come out the next time you want them to!
ChuckW is offline   Reply With Quote
