Question about drop shocks with flip kit?
I am going to spend the money to buy a full belltech system. But the thing with this kit comes drops shocks. But my question is that if I use the drop shocks for the back do I have to buy shock extenders?
Re: Question about drop shocks with flip kit?
No, you won't need shock extenders with drop shocks.
John 82 Chevy Silverado 350ci/TH350 ![]() |
Would rather run shock extenders though. Sets the rear shock angle better
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I would run shock extenders like insidious86 says also you have to grind the lower shock nut on driver side to get it on.It sits right on top of the plate were your u bolts run through.
Would you or any one else happen to have a picture of this where this was done? For referrence.
![]() Mine run with two and are fine. You can also weld them which is my suggestion Posted via Mobile Device
Here is a pic of what i ran into.Another thing is running 15" rallies you will have to grind the lower control arm.This is a 5/6 bell tech drop.
ok well thats what im going with is a 4.5/6 bell tech kit. But what part is needing or suggested to be welded to the axle?
also I dont if my wheels are considered to be rallies but the are deffinately 15's
#11 | |
yeller
I have run drop shocks on all my lowered squares, never had an issue. Plus, the shocks bolt right up, no need to deal with the hassle of extenders.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#13 |
