Grill swap question
Hi guys,
I own a 62' c10 with the original grill & am contemplating putting a 63' c10 grill on my truck.Besides the grill itself, what if any other parts will I need to do this ? Any fab/custom work,necessary ? Thanks as always ! Posted via Mobile Device |
1961 crewcab
Re: Grill swap question
62 to 63 should be a straight bolt in , no problems
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Great ! So do I need any other 63' parts to hang this grill on my 62' I've no experience with sheetmetal stuff...thanks again.
1961 crewcab
nope as long as the 63 grille is complete , just unbolt it from a 63, and bolt it onto your 62
What a country ! Lol thanks
I thought the grill mounting locations were different for 62-63? 63 Has 4 bolts that hold it on. The grill support is the same, but I believe the mounting points are going to have to be drilled.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
1961 crewcab
As far as I know 60-63 and gmc use the same mount points.
#8 | |
1961 crewcab
I will put my 62 and 63 grilles next to each other when I go out to the yard later today, and get you some exact measurements, you might have to drill a couple holes for the bottom. luckily the top outer corner mounts are in the same spot on all 60-66, so if needed you can hold any grille in that way, I did that when I ran a 62 grille in my 65 for a few weeks.
#9 | |
I got the grill today, decent shape & surface rust only, one small dent near the pass. Side headlight. I'm gonna clean it up a bit then hang/mock it up before the truck goes into the body shop (yes !) I am missing the bezels....hint,hint.
