Engine Bracket help (please)
Hey every one
I started to get the engine back in my truck last weekend but could not fine my engine mount brackets (brackets the bolt to the engine) I found a local guy on CL selling some from a 70's truck would they work in my 87 8v? he says there all the same i'm clue less? thanks |
Re: Engine Bracket help (please)
small blocks are all the same unless the brackets (clamshells) are from a car
just fyi you can buy them new aftermarket and all over ebay if the CL doesnt pan out
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
I'm assuming it's a 350
http://www.oreillyauto.com/site/c/de...2327&ppt=C0019 http://www.oreillyauto.com/site/c/de...2327&ppt=C0019
Joe __________________________________________ 1975 C10 "Questions are a sign of intelligence indicating a desire to eliminate ignorance" |
Small block then....O'Reilly's or Autozone can fix you up
If you're missing the steel clamshell (the half that bolts to the block):
![]() then the clamshells from a 73 and up truck will work. Right and left should be the same IIRC. If you're missing the other half of the mount (the steel and rubber half the bolts to the frame) then go to the part stores |
and BB are the same as the SB did a 454 to 350 swap and they fit like a glove
1978 GMC C25 LWB
#9 | |
thanks to every one else also for taking time out to help! |
4wd's use car mounts with a plate behind them like in 1981Stepside's picture. 2wd mounts are different slightly different. the 2wds all interchange from 73-87. the 4wd's interchange 73-87 and cars 73-87 maybe newer. Also as previously mentioned both big block and small block are the same.
sorry, should have specified the 4X4 in the pic - just a random grabbed from google
Proud UA member since 2009 My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660 Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA |
they should be part number 334601 and 334602 , the nut end goes to front
#13 |
Can you tell me what the physical difference (if any) there is between the 334601 and the 334602?
Having slight alignment issue with engine fan setting closer to right side of shroud. I have the 334601 on the right (passenger) side of the engine block and the part number on opposite side is not ledgible, but i am assuming it is the 334602. This engine with mounts and all brackets came out of one owner stock 350ci 77 chevrolet C10. Did i screw up and need to reverse these two mounts left to right to fix my issue? |
| Bookmarks |
