Old 09-21-2012, 11:33 AM   #1
68c20lwb
68c20lwb's Avatar
Please help with these manifolds!
Will either of these work on my 68 C20 454 4 speed? Which will work better?
http://www.ebay.com/itm/310427159921...84.m1438.l2649
http://www.ebay.com/itm/310406104497...S:1123&vxp=mtr
The key is will they fit with my 4 speed?
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear!
1969 C30 Open Road Motorhome 350/th400
1972 K10 350/350/205 Daily Driver -SOLD
68c20lwb is offline   Reply With Quote
Old 09-27-2012, 08:46 AM   #2
68c20lwb
68c20lwb's Avatar
Re: Please help with these manifolds!
nothing?
Old 09-27-2012, 08:51 AM   #3
OJ1988
Just a car guy
OJ1988's Avatar
Not sure, On a small block rear dumps won't clear the clutch, not sure about BBC.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-27-2012, 09:36 AM   #4
midniteblues
midniteblues's Avatar
I'm not sure either but i'm intrested in what you find out I have this set from a 75 chevy truck with a auto (almost like the first set) that I plan on useing when i start doing the bb swap I'm hoping they clear everything.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 09-27-2012, 10:23 AM   #5
RHestand
I just went out and looked at my 71 C-20 with headers and a 502" crate motor and I would say, IMO, with the rear dumps the clutch bell-crank would not let the head pipe go through.
Of the two sets, I would say the 2nd. set stands the best chance of working but not necessarily with off the shelf head pipes. In other words, you'll probably have to take it to a good quality muffler shop to get your exh. system custom bent and hung.
What I'm trying to say is "I doubt you'll be able to order a prefab exh. kit and expect it to connect up to those manifolds.
Good Luck, Ray
RHestand is offline   Reply With Quote
Old 09-27-2012, 11:03 AM   #6
RHestand
IMO, I would say the same to you as to 69c20. Your manifolds will probably work but, you'll probably have to have custom bent pipes.
Ray
Old 09-27-2012, 11:54 AM   #7
midniteblues
thank you for checking ,I'm guessing your oe bb 71 ones dump a lil' further forward on the ds
i'm not sure but i cant see why gm would use a differnt ds manifold for manual trans bb than a auto bb truck in 75(I no I no wrong years but these were free) unless the mt crossmember has something too do with it. my ds still has part of the head pipe and it does go straight down for quite a distance but i do know it "was" a custom deul exshaust
Old 09-27-2012, 02:07 PM   #8
68c20lwb
68c20lwb's Avatar
i do know i had manifolds that came with my big block, (84 C30 4 speed 2wd) that worked but were cracked terribly on both sides and i guess couldnt be brazed. so now i have just been searching, it is nice, although strange, to know that the manifolds are different. I wanted to purchase the magnaflow kit which requires your own lead pipes anyway. all i need are manifolds
Old 09-27-2012, 03:19 PM   #9
blackdawn
if you plan on redoing your exhaust anyway, why not throw a few more bones at it and get headers?
1969 c-10 short bed stepside - work in progress
blackdawn is offline   Reply With Quote
Old 09-27-2012, 11:12 PM   #10
68c20lwb
68c20lwb's Avatar
I had headers, 3 different kinds, i was told they were all going to work. None did. So now after having over $1,000 in headers that dont work with my 4 speed I am going with manifolds. Which still seems to pose a problem that I do not understand because the factory did it so why cant I? Anyway, I no longer trust summitracing customer service, at least not more then I trust myself. I think I may order up those vette manifolds and see if they fit right.
Old 09-28-2012, 12:06 AM   #11
SS Tim
SS Tim's Avatar
Don't you think it is unfair to blame summit's tech people for your problem. There have been several threads on this engine issue. Your truck was what a SBC then I6? I6 mounts and stands won't work properly. Stand location is also different. The clutch linkage has been a problematic and you were advised that the big block has specific linkage, mounts and trans. crossmember as well. Is it any suprise that headers designed to fit a stock big block application won't fit your truck? Please sit down and reread all applicable threads. Identify what you have and what you need to do to install the motor correctly. At that point any of you "incorrect" headers should fit.
http://67-72chevytrucks.com/vboard/s...d.php?t=540789
Also it has just come to light (to me) that your existing '68 frame has hacked up mount locations.
http://67-72chevytrucks.com/vboard/s...d.php?t=542561
Might want to decide what you want to do here about the frame first.
If you have questions about mounts look at this.
http://67-72chevytrucks.com/vboard/s...d.php?t=437680
SS Tim is offline   Reply With Quote
Old 09-28-2012, 01:48 PM   #12
68c20lwb
68c20lwb's Avatar
The Truck was a small block originally yes. I then went to a BBC. The BBC is in the truck as the factory did so using all factory components. Yes I did spend the time and money to do so. It took quite a while. I have done quite a bit of research on this although maybe I have missed a crucial part. As stated in my original question I am now simply wondering about exhaust manifolds. I no longer would like any sort of headers in my 68. Thank you for taking the time to follow me and I do appreciate your concern but at this point I have moved my direction and am simply moving to exhaust manifolds.
Old 09-28-2012, 01:50 PM   #13
68c20lwb
68c20lwb's Avatar
Yes the frame has been notched to fit incorrect headers on my behalf, nevertheless not affecting mounting location, position, or fitment. If that is a concern on another level please feel free to share I am happy to listen.
