Old 09-21-2012, 03:23 PM   #1
BigCountryx
BigCountryx's Avatar
CPP sway bar hits TRE
3" springs and 2.5" spindles, CPP sway bar hits the TREs at ride height. I shortened the end link and now it seems to clear, but did I do something wrong that's not obvious to me?
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 09-21-2012, 04:38 PM   #2
big_al_71
big_al_71's Avatar
Re: CPP sway bar hits TRE
I had the same exact problem with mine I ended up taking off with I switched to air bags and installed the muscle bar from ride tech...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 09-21-2012, 04:59 PM   #3
newbe351
I had the same problem when I bought new rims with 4.5" backspace. I switched out to an original mount style bar from Early Classic Enterprise. No problems now, plus it's a heavier bar......
newbe351 is offline   Reply With Quote
Old 09-23-2012, 07:52 PM   #4
LEEVON
Moderator
LEEVON's Avatar
x3. I even fabricated new parts to raise/lower the frame and a-arm mounting points. It will ruin your pitman arm, hitting the bar like that so be careful. A little annoying that this is advertised as a bolt-in because I'm not sure how it would work unless you have rack and pinion...hopefully I can use mine on another project in the future.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
