Old 09-21-2012, 05:08 PM   #1
Steve Cole
TH400 Question
Could someone please post a pic of the electric kick down switch mounted in the truck? Thanks!
Steve Cole is offline   Reply With Quote
Old 09-21-2012, 06:22 PM   #2
GMCJOE
GMCJOE's Avatar
Re: TH400 Question
Here is a thread with a few:
http://67-72chevytrucks.com/vboard/s...d.php?t=313083
Aftermarket set-up I found on google:
http://media.photobucket.com/image/r...l/DSCN4179.jpg
Joseph
Joe's 69 GMC
http://67-72chevytrucks.com/vboard/s...d.php?t=543253
1969 GMC SWB-350 SBC 700R4
2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust
GMCJOE is offline   Reply With Quote
Old 09-21-2012, 07:15 PM   #3
JimKshortstep4x4
Re: TH400 Question
You might try getting one for a Camaro as they had the same set up.
Here are some pics of an installation and what one vendor has for parts.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 09-21-2012, 08:47 PM   #4
jd7
jd7's Avatar
Re: TH400 Question
have you looked @ the lokar set up Im installing mine 2mro ?
jd7 is offline   Reply With Quote
Old 09-21-2012, 09:37 PM   #5
bollybib
bollybib's Avatar
Re: TH400 Question
Anyone ever installed a kickdown switch on an Edlebrock 1406 and have pics ??? I see the one using the pump lever, any other ways to do it ?
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 09-21-2012, 10:14 PM   #6
Steve Cole
Re: TH400 Question
Thanks for all the help guys. I would like to see the Lokar setup. My truck is a '68 and never had a TH400 in it before so I will have to install my own switch from somewhere. I am wanting to install a 71-72 cable style pedal so I guess I will need to come up with a carb mounted switch instead of the pedal style.
Old 09-22-2012, 06:13 AM   #7
oldspowered67C10
Re: TH400 Question
I have the Lokar set-up on my edelbrock carb. Its not carb mounted but rather has a cable that runs to small aluminum box you can mount anywhere. Be warned though, it will only work(as far as I know) with the Lokar throttle cable and bracket set-up.
oldspowered67C10 is offline   Reply With Quote
Old 09-22-2012, 06:11 PM   #8
Steve Cole
Re: TH400 Question
Hey Oldspowered, you got a pic of that setup?
