Old 09-21-2012, 06:13 PM   #1
62lwbc10
Deluxe Cab trim on 58
Hello All, I recently procured a restored 58 short step and I need to install the deluxe trim on the doors and cab. The truck has not yet been delivered to me, but the deluxe trim was original and the holes are already in the cab. Is it a pain to install these trim pieces?
Regards,
Mark
62lwbc10 is offline   Reply With Quote
Old 09-21-2012, 09:13 PM   #2
oldcouple
oldcouple's Avatar
Re: Deluxe Cab trim on 58
If you have the clips should be easy, tape the body off if its painted. Those holes will leak so I have heard of guys using silicon on the back of the clips and letting it set before installing the trim.
Retired and too busy to work.
oldcouple is offline   Reply With Quote
Old 10-02-2012, 12:37 AM   #3
TX58
I also want to know the trick to installing this trim
TX58 is offline   Reply With Quote
Old 10-02-2012, 02:38 AM   #4
hp1957
hp1957's Avatar
Polish Custom Cab Trim first, use lots of blue painter tape around doors & cab, clean clip holes, w a helper line up clips & gaps one piece at a time, start at one end push clips lightly w two fingers til you reach the other end, & tighten nuts on door trim.
Harvey
1957 Chevy Stepside
1958 GMC Fleetside C4 build thread: http://67-72chevytrucks.com/vboard/s...65#post5510465
hp1957 is offline   Reply With Quote
