09-21-2012, 08:49 PM | #1 |
Frame Upgrade Question
Good Morning All,
I am proud owner of a 1964 Chevy Panel Truck (half ton) I am planning on swapping out the complete front K member (Crossmember) with a mid 70's unit. My understanding this will be a direct bolt, then i just saw a thread saying only if they are both half ton. so is it true a 3/4 ton front will not bolt in, and if so, what is the differences? also, is there an online reference that details the frame specs over the years. I need to make sure i build a safe frame Thanks all! cb |
09-22-2012, 01:00 AM | #2 |
60-66 Nut
Re: Frame Upgrade Question
Welcome to the forum
You can bolt up a '71-'87 C20 front suspension just as easily as a C10 suspension. Take a look in the '60-'66 FAQ thread at the top of the main '60-'66 forum page. There are a few front suspension threads listed in there. The most complete one is titled 'Disc Brake Upgrade Reference Thread'
09-22-2012, 01:13 AM | #3 | |
if you are talking about the frt springs and brackets; they have to be relocated ron |
09-22-2012, 11:02 AM | #4 |
Are we talking 2WD or 4WD?
If it's a 2WD, the entire cradle and suspension will bolt in. You will have to drill 2 new holes and elongate 2 existing holes. Super easy. Buy a steering box adapter from Capt. Fab, and you'll have power steering as well. I would recommend this swap to anyone who wants to stop and steer better. Plus, you're using all GM parts, and that's a nice feature when you have to buy replacement pieces from the local parts store. If it's a 4WD, it gets a little trickier. You'll have to do some fab work, but not too much.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
09-22-2012, 11:10 AM | #5 |
Good Morning All,
It is 2WD. Here is two pic i shot this morning Thanks all Chris |
09-22-2012, 11:14 AM | #6 |
when you use "K" that pretty well refers to 4 wheel drive
ron |
09-22-2012, 11:32 AM | #7 |
interesting, I have also known the K member is the main assembly that is the center unit that the control arms bolt to and supports the engine,,,
well because it looks like a K since im a jeep and dodge guy, 4wd means dana 30,44,60 front axles (dont flame me ) sorry for the confusion Chris Example of a fabricated unit Last edited by 1964Panel; 09-22-2012 at 11:57 AM. |
09-22-2012, 12:06 PM | #8 |
[QUOTE=1964Panel;5606230]interesting, I have also known the K member is the main assembly that is the center unit that the control arms bolt to and supports the engine,,,
well because it looks like a K since im a jeep and dodge guy, 4wd means dana 30,44,60 front axles (dont flame me ) sorry for the confusion Chris Example of a fabricated unit [/QUOTE in chevrolet light trucks 2 wheel drive are "C" model designation and 4 x 4 are "K" designation in the models. in your panel look at the ser#. 1st there should be the #4 for the year and then there will be a "C" which will tell you that it is a 2 wheel dr.conventional cab I understand this in your relationship with a dodge ron |
09-22-2012, 09:56 PM | #9 |
Yup. I follow what you are saying, I guess when i was thinking K member, It did not dawn on me that K and the 4x4 designation
