Old 09-21-2012, 10:24 PM   #1
BrianPlaster
BrianPlaster's Avatar
Talking heating up my springs..
I gotta 72' that I wanna lower / should I heat the springs up or cut them ?
Can I heat them up while leaving them on ? or should I take them off and cut them ?
Help me out / I wanna get some lowered springs but I just putt around town and don't really want to buy anything but gas on this truck.
BrianPlaster is offline   Reply With Quote
Old 09-21-2012, 10:29 PM   #2
TheSeeker
Re: heating up my springs..
The safest, easiest way is to buy drop springs. However, I am in the crowd that has not been in the money, and cut springs properly. I know plenty will scoff at the idea, but if done correctly cut springs are perfectly safe. Measure three times, cut once haha.
I would advise agaisnt heating them at all, seen way to many botched jobs, hell ive seen some practically FALL out when jacked up because of poorly heated spring lowering jobs. Just my two cents. Good luck and BE SAFE.
TheSeeker is offline   Reply With Quote
Old 09-21-2012, 10:30 PM   #3
ole dollor
ole dollor's Avatar
i did that on my daughters truck several years ago....she loved it ...i thought it road like you know what....i heated them on the truck.....make sure you do it real slow and measure a lot.....if you don't like it...just buy 4 new springs...
ole dollor is offline   Reply With Quote
Old 09-21-2012, 10:31 PM   #4
50bomb
50bomb's Avatar
Neither. Save up and do it right the first time. Safety comes first.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 09-21-2012, 10:38 PM   #5
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Take them off and cut them half a coil at a time with a cut off wheel so you don't change the spring's temper and check your alignment after you find a height you're happy with. I would even drive it for a few days between each cut to see how it rides and settles.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 09-21-2012, 11:07 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Nobody has mentioned it yet but you can't cut the rear coil springs. They are tapered on both ends. You can do lowering blocks on the back, up to a 2" drop. Don't heat them. One coil cut off the fronts = 2 1/2" drop.
Just my 2˘ worth.
LockDoc
Leon
Old 09-21-2012, 11:21 PM   #7
weever82
weever82's Avatar
You can buy the cheap "universal" blocks for the back and are only like $50 for the set.
However if you are set on doing it for free... never heat, at least cut them. Be safe!
Weev-
Weev-
Life's tough...... It's even tougher when your stupid - John Wayne
weever82 is offline   Reply With Quote
Old 09-21-2012, 11:21 PM   #8
OutlawRider
I've not looked to far into it, so sadly this statement doesn't hold much research behind it like I would prefer to post. But could you not safely cut a spring and wled on a spring retainer and a plate that would secure the spring to the axle? I mean worse comes to worse, have some good bump stops and if one falls out, you hit a bumpstop and not the ground.
OutlawRider is offline   Reply With Quote
Old 09-21-2012, 11:30 PM   #9
shawno72
C/10 junkie
shawno72's Avatar
Get ahold of Boris (way2lo2) he has drop blocks with u bolts and hardware for like $65 shipped.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 09-22-2012, 12:41 AM   #10
jrdv
jrdv's Avatar
I'm not saying it is ok, but I cut the front coils and heated the back coils on my swb71 chev and drove it for over 20 years. I had no problems. This year, I did the ECE 4/6 drop. The ride was much improved and it looks better. The biggest improvement is that I don't have the side to side movement when I go over bumps.
Do what you want. I know lots of people who have done this. Most likely you will uprgrade to the correct springs eventually.
jrdv is offline   Reply With Quote
Old 09-22-2012, 01:37 AM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Cut the front sprigs 1 coil
Rear, contact borris way2low for a 2" drop block/ u bolts
hubscrubs wifes truck had/has cut rear springs I tell him hes tryin to get rid of her when she drove it to the cruise in a year ago
John
1999 Toyota Tacoma 4x4
Old 09-22-2012, 02:13 AM   #12
cdowns
cdowns's Avatar
actually the wose comes to worse scenerio ends up with the truck wrapped around a pole and the steering shaft thru your chest lots o blood everywhere too
HALF A$$ ENGINEERING KILLSS
Old 09-22-2012, 07:27 AM   #13
BrianPlaster
thanks for all the advise on heating versus cutting versus buying them.
Brother's is having a sale on the springs and shocks so I;m going to go that direction. The Brother's sale is on until the end of October and they are really nice on the phone . I'll be sure to post pics.of the before and after.
Also looking for an extra set of wheels (5 lug's) in the NC area
Old 09-22-2012, 07:57 AM   #14
BrianPlaster
I have lots of questions being that I dove head first into c-10's about a year ago. I want to fix my gauge cluster / speedo and oil pressure work but fuel and temp gauges don't ???
I figured I'd remove it and clean it up at least but I can't get the lights button off ??? Is it screwed on or does it pop off ? trying not to break
Old 09-22-2012, 08:26 AM   #15
SS Tim
SS Tim's Avatar
This thread will help with the cluster.
http://67-72chevytrucks.com/vboard/s...d.php?t=543530
SS Tim is offline   Reply With Quote
Old 09-22-2012, 08:40 AM   #16
50bomb
50bomb's Avatar
BrianPlaster Good to hear your gonna buy them at brothers instead of the heating/cutting technique. You will be SUPER Happy with the brothers lowering kit.
Old 09-22-2012, 08:41 AM   #17
BrianPlaster
I love this site ! I tried for the last 6 months to figure it out and on this site it took 6 min
Old 09-22-2012, 09:46 AM   #18
CC69Rat
CC69Rat's Avatar
Brian, remember your factory springs have likely sagged a little over the years. With a 2" drop spring (new) keep in mind you will only likely net about 1.25 or so drop. The truck will settle a little as you drive it .. maybe 1.65 or so drop from start to finish.
Cutting the factory spring one full turn will give you 2.5" full net drop. IF you cut them, I wouldn't go over one full turn and cut it with a cutoff wheel. (as stated)
Drop spindles are very easy to install while you have it apart. Just a thought. .. That's the best way to do it and you don't have to worry about alignment and that extra $75 or so to get it done correctly. There were some 71-72 spindles in the parts section the other day.. not sure if they are still available.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 09-23-2012, 11:56 AM   #19
BrianPlaster
do you have to have disc on the front to use dropped spindles ?
Old 09-23-2012, 03:40 PM   #20
oldblue1968chevy
yes
John
Old 09-23-2012, 10:04 PM   #21
mr mike
mr mike's Avatar
Just my 2˘ worth.
LockDoc
You can put 1997 and up Jeep Wrangler spring in your rear of the c10
That's what I did and it dropped it about 4" but the spring I put it was
Used and had a little sag going on.
the truck click the link..
http://67-72chevytrucks.com/vboard/s...d.php?t=361168
mr mike is offline   Reply With Quote
Old 09-23-2012, 11:08 PM   #22
lowrollin70gmc
Too many projects
You have to have disc, but being a 72 you should already have front discs.
Andrew
Old 09-24-2012, 01:52 AM   #23
oldblue1968chevy
My advise (dont listen I usually dont either) I bought some TJ springs, they dropped it 4" If you put ANYTHING in the bed you were on bumpstops. Wayyyy to lightweight for a truck dont bother.
If you really want some I have my old set I'll sell you lol
John
Old 09-24-2012, 02:16 AM   #24
Xeen
Xeen's Avatar
I dont know if you are aware of this so I thought I would mention it just incase.
You cant lower the front end more than 2" with factory spindles because the geometry will be unreconcilable, so 2" drop springs are the best you can do without buying drop spindles.
That means you can drop the rear up to 4" if you want to level out the truck or 3" if you want a slight rake.
happy trucking!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 09-24-2012, 02:37 PM   #25
GRX
GRX's Avatar
Originally Posted by lowrollin70gmc View Post
Take them off and cut them half a coil at a time with a cut off wheel so you don't change the spring's temper .....
x2 ... heating springs is a big NO NO
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
