09-22-2012, 05:41 PM | #1 |
brake issues
Took our 66 for the first ride from a 3yr rebuild and the right rear is locking up under moderate braking. Everything is new except for the proportioning valve, new hard lines, rubber lines WC, MC, Calipers and hard lines. We used 72 disc brakes and a used 72 prop valve, S10 8" booster and MC. I'm pretty sure it's plumbed up right. My son took the plug out of the little shuttle valve and said it was spring loaded and he could push it with his finger. I heard talk about a button on some of them but ours doesn't have one. Any ideas? We are hoping to get it registered and hit cruisin the coast in MS in a couple of weeks.
09-23-2012, 08:56 PM | #2 |
Re: brake issues
For some reason the proportioning valve is blocking off fluid to the front brakes. I've tried opening the bleeder to the rear and stomping the pedal to try and get it to center back up and no luck. Put another valve on and same thing. Anyone had a problem like this? There has to be a brake guru on this site that has some input.
09-30-2015, 06:14 AM | #3 |
Re: brake issues
I am having similar types of issues with my truck. Rear brakes (not sure which wheel) locking up under moderate braking power. I assumed it was associated with the proportioning valve somehow. I cannot seem to figure out a way to narrow down the problem. Do you have a brake warning light hooked up to the valve. If not, you should try hooking up a test light to the battery and connecting it to the pin to check for a ground, which would indicate an offset valve in your case. Mine does not, yet it still seems to have an incorrect pressure distribution to the front/rear.
anyone have any suggestions for us? |
09-30-2015, 07:08 AM | #4 |
Re: brake issues
Try looking at the adjustment between the two sides on the brake shoes. Mine did it some early on and I readjusted them. Now that they have had time to seat under hard braking they both will lock and a little more pedal they all lock. I just attribute it to the weight balance of the truck. Under stiff braking the back gets pretty light.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-30-2015, 07:33 AM | #5 |
67-72 parts collector,…
Re: brake issues
Are you sure sure you are getting full stroke out of your M/C?
You may need to lengthen your brake pedal pushrod.
09-30-2015, 10:54 AM | #6 | |
Re: brake issues
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-30-2015, 05:39 PM | #7 | |
Re: brake issues
I kinda always assumed that because it does have such a light rear end that it would eventually have to lock up at a certain speed. i just read a whole bunch of articles about brake bias, and combination valves etc..and it got me testing my own truck, and thats where i was able to continuously lock up the rear, when i feel like maybe it could be out of adjustment somehow. |
