What Lubricant to use on my slip yoke grease zerks
Re: What Lubricant to use on my slip yoke grease zerks
I just use the water proof grease I have in my grease gun, same stuff I use for all my suspension on everything.
i use marine grease in everything do to the salt in my area. never had a problem also i cover the tip of the fitting so it does not freeze with rust. next time i grease i wipe down and do it again.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
x2...marine grease
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
for that application I suggest Mystic JT-6 no.2 high temp grease.
I use a water proof, high temp, marine grease, same thing I use on all my suspension, u-joints, and packing wheel bearings with.
Back when I was at the dealership, they had Lubriplate. Marine grease, or molly grease will work just as good as Lubriplate, if not better.
