09-23-2012, 09:21 AM | #1 |
72 proportioning valve
I know this should go under the brake forum but I'm not getting any response over there. I have a proportioning valve from a 72 and it doesn't have a button to re-center the shuttle valve in it, it just has a plug in the end. Anyone had a problem with one of these? how do you re-center it?
09-23-2012, 09:57 AM | #2 |
Re: 72 proportioning valve
Remove the plug. The button should be under it. To recenter mine, I just stomped on the brake peddle a few times until it "popped" back into place.
-Scott- |
09-23-2012, 10:07 AM | #3 |
I found this. Did you do a search?
http://67-72chevytrucks.com/vboard/s...d.php?t=336053 |
09-24-2012, 09:34 AM | #4 |
Tried all that and installed another valve. I think the new MC is bad on the front side. Going to replace it today and see if it fixes the problem.
09-24-2012, 09:43 AM | #5 |
67-72 parts collector,…
Do you have any pics of your M/C set up?
09-24-2012, 12:50 PM | #6 |
Don't have a pic, I'm at work right now.
09-24-2012, 01:11 PM | #7 |
Hmm... I have the same valve, though brand new, since I'm converting over to '72 discs. I was not aware there was any magic in terms of setting these up, I thought you just plumbed them and bled them.
I'm guessing there is a shuttle valve that can stuck to one end and cause problems, but beyond that I have no idea. Would someone be so kind as to tell me what it is that I don't know? I'll refer to the shop manual when the time comes, but helps if I know in a general sense what's going on. Sort of like finding out one day that there are muffler springs and you had no idea!
09-25-2012, 12:10 PM | #8 |
The proportioning valve has a centering valve I believe it is called. This valve is in case you severe a brake line or blow out something the pressure from the good side of the brake system will force it in the opposite direction to cover the port on the low pressure, or blown out side so you still have some brakes. I have never had this issue while bleeding a brake system before but until the system is bled and the pressure is equal on each side there is the possibility of this happening. There is a tool designed to go in place of the brake switch while bleeding to prevent this from happening, I found a picture of one on the net. I seem to have it fixed, not sure what it was changed the MC and cleaned the prop valve.
