1980 SWB Frame Questions
I have this 1980 SWB I was planning to use the parts (frame, fuel tanks, rear end) under my 86 LWB to convert it (long beds suck!) but I'm not sure on the frame. It has what appears to be damage although it could have been made this way. Hopefully you guys can help.
Does this look like factory or accident damage? ![]() ![]() ![]() ![]() That is all on the drivers side next to the fuel tank. This is pass side ahead of fuel tank.. ![]() ![]() And this is top of frame where it kicks up for rear wheels.. (yes thats the factory paint!) ![]() ![]() ![]() What do you guys think? |
Re: 1980 SWB Frame Questions
The top of the rail looks factory to me.
The bottom areas look like damage from jacking the vehicle up off the flange of the frame. My $0.01 - K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
My 81 looks identical to yours
Posted via Mobile Device |
Really, hmmm...seems like i remember hearing something about GM putting a bend or something in these frames to make it easier/faster for assembly line workers to get the trans crossmember into the frame. But this crossmember goes under the frame, not between the rails
so that don't make sence. You guys ever hear anything like that? Posted via Mobile Device |
#5 | |
That would be a semi regular occurance; there can also be strange formations to clear catalytic converters or other exhaust components, clearance for tools in the forming dies or assembly tooling, but I don't think that's what we are seeing here. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-24-2012 at 06:56 AM. |
I'll take a look at my '87 the next time I'm out in the garage.
K
Yeah the bottom of the frame looks like a jack used wrong or something hit it,The top that is normal you have to remember these are mass production trucks some parts no one sees can have waves from stamping.Its not just gm i have seen fords and dodges have waves in stamp sheet pieces before.
Thanks for the info. Its mostly the lower part by the drivers fuel tank i am worried about. Would take alot of force, imo, to bend it like that.
A 3/8" bolt and nut is the factory repair for a mis-hit rivet. Looks like someone was a little "off" that day.
I tried to get them to use all bolts (instead of rivets) on the spring hangers when my truck was built but was unsuccessful... ![]() K
Was that a pretty common occurrence? (having an off day and missing rivets)
Do they still use rivets in new(er) truck frame construction? |
