Old 09-23-2012, 09:43 AM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Pics of exhaust routing
I am getting ready to run the exhaust on my 72 K10 Suburban and want to know how you guys are getting past the transfer case with your pipes. (over or under). If anyone has some pics of what you did I would appreciate it. I am also running headers.
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 09-23-2012, 02:13 PM   #2
msgross
msgross's Avatar
Re: Pics of exhaust routing
seen both, stock was a y-pipe the went down the drivers side (and avoided the t-case)...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 09-23-2012, 08:22 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
If you do any 4 wheeling you have to run it above the cross member, otherwise its gonna get damaged. Its real tight on the pass side, but a good exhaust guy can get in thru there.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 09-23-2012, 08:58 PM   #4
You just need to start out with these:
Old 09-23-2012, 09:52 PM   #5
Scott Johnson
Junior Member
Thanks for the responses guys. If you go over the transfer case how close is it to the floor of the truck? It looks like its going to be tuff to get it over and have clearance on the t case and not be too close to the floor. I dont want to go under and it hang down too low and be seen.
Old 09-24-2012, 01:15 PM   #6
Here is how the pipes I showed you go through. The driver side is 8-9" from the floor and sits at about a 45 deg. tilted inward. The passenger side is turned straight up and is no less than 3" from the floor. First two pictures are the driver side. These pipes and headers have been on since '04 with no issues. It's tight on the passenger side,but no problems. I guess the pipe could bend up higher to clear the transfer case and cross member more,but then would be closer to the floor. I have these made up from 5' of pipe and keep them around to bolt up when I take a truck to the exhaust shop. I just stick the mufflers on to get there and they cut or bend that front pope and go from there.
Old 09-24-2012, 01:18 PM   #7
It's hard to see in the first picture. That light colored line above the spring clamp is the collector gasket. The pipes run high and dry inside the frame the whole way back.
Old 09-24-2012, 11:28 PM   #8
Scott Johnson
Junior Member
Thanks Tim, thats what I was looking for. I was thinking the pipe would be too close to the transfer case on the passenger side, but if it works for you, I will give it a shot. Would much rather have it go above than below. I appreciate you taking the time to post the pics.
Scott
Old 09-25-2012, 04:36 AM   #9
birdistheword
birdistheword's Avatar
Here's mine on my 72 K-10. It's got headers, 3in pipe, and a body lift.
birdistheword is offline   Reply With Quote
Old 09-25-2012, 06:59 AM   #10
The pipe (2.5") clears the t-case by 1/4" or more. Pretty close but you'll be fine. There may be a way to give more clearance. My method is to allow me to drive it there with some sort of exhaust on it. If custom bent from the headers "on site",the guy might do something a little different. I just had the pipes on a truck I owned copied years ago and keep a couple pair stashed. When I get to one pair I have another pair made. They just charge their minimum and do it in 10 minutes.
Old 09-25-2012, 07:22 AM   #11
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Not a 67-72 but the cross member arrangement is the same. The pipe is 2.5" from tip to tail.
DirtyLarry is offline   Reply With Quote
Old 09-25-2012, 07:48 AM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
Make sure the pipe is not touching anything after the exhaust shop is done. It will rattle and drive you nuts.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 09-25-2012, 08:37 AM   #13
jjzepplin
jjzepplin's Avatar
What kind of tranny is that?
I used headman "s" collectors and long tube headers.
They made it easy to go around the t-case.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-25-2012, 11:12 AM   #14
DirtyLarry
DirtyLarry's Avatar
NV4500.........regarding headers, I don't believe in them.
Old 09-26-2012, 10:59 PM   #15
Scott Johnson
Junior Member
Thanks for all the pics guys, hopefully I`ll be adding a few of mine soon.
Old 09-27-2012, 08:05 AM   #16
Looking forward to it. Suburban,huh?
Old 09-28-2012, 08:24 AM   #17
Scott Johnson
Junior Member
Yes its a Suburban, hopefully get time next weekend to get this done.
Old 09-28-2012, 10:22 PM   #18
Billhilly
Billhilly's Avatar
Hey Scott, How are you?
Here's one more shot, from above. Plenty of room, mines running a little high.
(The PTO box finally made it down here, thanks again).
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 09-29-2012, 11:04 PM   #19
Scott Johnson
Junior Member
Hey Bruce, nice pic, glad you got the PTO adapter.
Old 10-20-2012, 09:00 PM   #20
Scott Johnson
Junior Member
Finally got time to do the exhaust, will finish past mufflers once the body is back on. Thanks for all the input, worked out well going over the transfer case and should have just enough room on both sides so it wont hit.
Old 10-21-2012, 12:07 AM   #21
Billhilly
Billhilly's Avatar
Looks really good Scott. Another piece of the puzzle done huh.
1972 K2500 Long Box
400/350
Old 10-21-2012, 10:29 AM   #22
OLDCHEV4X4
OLDCHEV4X4's Avatar
That looks real good.
Did you fab that? Did you paint it? Or is that aluminized pipe?
Is the spedo cable gonna clear?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 10-21-2012, 09:40 PM   #23
Scott Johnson
Junior Member
Yes, I bent them myself, I have access to a pipe bending machine, I painted the pipes with VHT flat aluminium paint. The speedo cable will clear no problem, it just looks close in the pics.
