09-23-2012, 09:56 AM | #1 |
U-Haul trailer
Will our trucks fit on one? Any issues?
09-23-2012, 10:14 AM | #2 |
Re: U-Haul trailer
It will but if it has wide wheels or mags it might not. I have used one in the past and loaded it but it is tight.
09-23-2012, 10:19 AM | #3 |
Re: U-Haul trailer
They are tight on a stock truck, if renting they frown on it too, when I went to rent one to move my 65 years ago they refused to rent to me, when I told them what I wanted to haul on it.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692 70 C-30 Tow truck AKA Highlighter 02 Silverado 2500 HD CUCVII Tow Rig/DD 1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800 1980 Buick Regal Dirt Stock car |
09-23-2012, 10:28 AM | #4 |
Re: U-Haul trailer
I'm hauling a 1990 Honda civic lol.
The truck has no drive train so it shouldn't be too much weight. Was looking if overall dimensions would work. Shortbed. Posted via Mobile Device |
09-23-2012, 10:30 AM | #5 |
Re: U-Haul trailer
Have recently hauled a '51 Chevy PU and a 1959 F100 on them. But both are significantly narrower than the 60-66's.
09-23-2012, 11:29 AM | #6 |
Re: U-Haul trailer
I just moved my '66 with wide mags from Virginia to Missouri on a Penske car hauler. What I did was measure the width of my tires and added two inches, then called and asked the width of the trailers. Both U-Haul and Penske had car haulers that were wide enough. I think I selected that I was hauling an El Camino or something. Good luck and drive safe!
09-23-2012, 11:33 AM | #7 |
Re: U-Haul trailer
Mine is a short trip. Just don't have a car trailer at the moment. Thanks for the info.
09-23-2012, 12:03 PM | #8 |
Re: U-Haul trailer
I just hauled my 64 short step about 400 miles on a u-haul trailer, pulled it with a 2001 f-150
Then I went back and picked up and just used a tow dolly, pulled it back with the same f-150. You will save a lot of money if you can use a dolly.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
09-23-2012, 12:04 PM | #9 |
Re: U-Haul trailer
I hauled a 63 1/2 ton w/ stock wheels on a uhaul trailer about six months ago with no problems. Uhaul wanted to know both what I was hauling and what I was pulling the trailer with and was fine with it.
09-24-2012, 01:35 AM | #10 |
60-66 Nut
Re: U-Haul trailer
My son recently rented a Penske car trailer, and he was told as long as the vehicle is 4000# or less it is fine. A complete C10 long bed is over that, so keep that in mind.
09-24-2012, 02:22 PM | #11 |
Re: U-Haul trailer
Go with Penske. I used them to tow my 70 C10 from N.C. to California! Their equipment is much cleaner and safer than UHAUL.
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
09-24-2012, 03:08 PM | #12 |
Re: U-Haul trailer
just a thought if there is any hub caps remove them before loading. with the tight squeeze they could be damaged
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
09-24-2012, 05:12 PM | #13 |
Re: U-Haul trailer
Hauled my 63 back with no problems:
First and Foremost: Thank you God for my Salvation! I pray that others will seek your Son, Jesus Christ! My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342 My 2013 Camaro 1LE: https://www.youtube.com/channel/UCxa...wL5d6RnmfdJa1A 86 C10 "Build Thread”: http://67-72chevytrucks.com/vboard/s...d.php?t=668777
09-24-2012, 05:43 PM | #14 |
Never Ending Projects
Re: U-Haul trailer
That's how my panel made the 150+ mile trip home. I just told U-Haul I was towing a Miata.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-24-2012, 05:45 PM | #15 |
Re: U-Haul trailer
I was just wondering this same thing. Wanted to go to slamfest but no way I will be able to drive that far right now and no tag yet either.
I was wondering if I could air my truck up high enough to even get it on the trailer. Im not sure about a dolly, isnt it bad to tow an automatic in neutural????
My build thread: 1966 stepside http://67-72chevytrucks.com/vboard/s...d.php?t=486223 1965 GMC fleet http://67-72chevytrucks.com/vboard/s...d.php?t=651726 |
09-24-2012, 06:02 PM | #16 |
Re: U-Haul trailer
You could just remove the driveshaft. And for a dollie with no tags on the truck you will get a ticket.
10-10-2012, 09:05 AM | #17 |
Re: U-Haul trailer
I know you guys have allot of info here, going to get my 66 c-10 long box. Will this fit the long way also?
Thanks allot.... |
