Old member
What are the best cleaner & polish for the aluminum on the Boss 338's?
I need to get mine cleaned up good. What is recommended for the aluminum. The picture was when they were installing them. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Old member
I ended up trying Never Dull. Seems to have cleaned them up nicely so far. Got both the driver sides done. Going to do passenger side in a few.
![]() ![]() ![]() ![]() Now what to put on them to keep them looking this good?
Re: Cleaning my wheels up
what you have looks good in pics
The best I have personally used for my alluminum wheels is "mothers". Rubs on white and will come off jet black from the wheel grime. Then buff it with a microfiber towel. You will have the cleanest wheels in town... next to mine.
![]() It's a little round white/red can. Weev-
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
Old member
Yea I've used the mother's before. What I had left looked dried out so I used the never dull.
Parts and more parts
I use the Mother's aluminum polish and then follow that up with Mother's Billet polish for a mirror finish. I use a detail spray to clean the black hardened aluminum polish off of the wheel between applications. I then seal the metal with a product from Wizards products, that is called "Power Seal" http://www.wizardsproducts.com/store...8-oz-p-15.html.
I have found that it works quite well in keeping the polished parts clean of water spots.
Frank |
| Bookmarks |
